1st build questions
Post Date: 2012-07-17
RClive View Drop Down
Avatar
  Quote RClive Quote  Post ReplyReply bullet Topic: 1st build questions
    Posted: 17 Jul 2012 at 11:50am
Hi Guys,
I’m putting together my first custom PC and could use some advice.
My main uses:
- Statistical modelling
- Some basic photoshop/video editing
- Streaming music and video
- Some gaming (maybe more than I think)
Other considerations
- Budget $2600
- I leave the computer on for long periods of time. At least on in the morning and off at end of day
- I often have lots of windows open
- New monitor in future, say Dell U2312 (1920x108) or even Dell U2711 (2560x1440)
- Quiet is important.
- It will be on the floor so dust may be an issue
- I plan on upgrading in the future, perhaps 2nd GPU, audio card, more hard drives, sound card, Blue-ray.
1) Case: I have thought about HAFX, Corsair 550D and 650D and am leaning to HAFX. I’m a little worried about the dust.
2) CPU: trying to decide between i7 3770K or i7-3930K or i7-3820
I’m currently leaning towards i7 3770K so I can fit an SSD+HD into the budget and I like the idea of a low power consumption build. Otherwise I could get the i7-3930K and wait on the SSD+HD. Doesn’t seem that the i7-3820 is enough of a boost in processing power.
3) Otherwise wondering if any upgrades are worthwhile: Motherboard, PSU, Cooling?
Heres the current config: Ticket Number: 709162
Total Price with Instant Savings: $2,538.00
Video Card: 1x NVIDIA GeForce GTX 670 2GB (PhysX) (FTW Overclocked EVGA) <b></b>
Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (High-Performance Edition)
Kyu View Drop Down
Avatar
  Quote Kyu Quote  Post ReplyReply bullet Posted: 17 Jul 2012 at 12:16pm
I'll figure out a config for you in a sec.
Dust will always be an issue, weither you go Loops or Air or Closed wc setups it'll still cause dust. You have to manually dust clean with a blower your self time to time.
But then there is this one option I went with for one of my pc's, I completely submerged it, Dust gone !
anyways I'm going to recommend the x79's over the z77 Platforms.
For your heavey cpu usage it's a better route.
adding Multiple GPU and higher Memory , heavey usage the x79 Will be a better direction.
z77 isn't meant for true sli/xfire and they aren't meant for heavey memory storage.
Kyu View Drop Down
Avatar
  Quote Kyu Quote  Post ReplyReply bullet Posted: 17 Jul 2012 at 12:19pm
System Memory: 32GB DDR3 1600Mhz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
Video Card(s): 1x NVIDIA GeForce GTX 680 4GB (Includes PhysX)
Again I chose the X79 Platform over the z77/z87
And also picked Hailstorm (Corsair 800D) more room, Keeps the case semi off the ground with really good cooling vent while having silent fans.
While the GTX 670 is plenty fast,
Assuming you're going IPS 27" shortly, the resolution does make a difference on the cards Performance when it's 1080 vs 1600
Might be the drivers but from 2GB vs 4GB I noticed a difference in maxed game play on my 2560x1600
Leaves you room to upgrade in the future but plenty for now
and within your 3k Budget
also I was assuming you had your own HDD for storage so I left that part out.
I personally use Drobo for Storage and share it linked with the rest of my PC's
16TB being shared with backup incase 1 drive fails.
At the end all the chose is yours
Edited by Kyu - 17 Jul 2012 at 12:25pm
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 17 Jul 2012 at 3:10pm
Hi Kyu,
Thanks for the quick reply. A lot of things to think about.
On the case, I thought about the 800D, but it seemed a bit too large for my purposes (Its deeper than the others) So would have to check if it would fit in the designated spot.
On the CPU/Platform, you may be right. The guys that write my statistical package suggested that processor speed, and the size of the L3 cache would have an impact, number of cores only comes into to play with very large data sets.
For the graphics card, I didnt realize that there was such a jump in requirement for the Dell U2711 (2560x1440), so need to digest that a bit. Wouldnt 2 x GTX 670 be sufficient?
Online Status: Online
  Quote FrankW Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 8:32am
Hi RClive,
I have some different thoughts that Kyu. Doesn't mean my opinion is better than his but I would make some changes.
1. The 800D is a poor choice for air cooling. It is built for LC systems. It doesn't make sense to use a case with bottom intake and then set it on the floor. For air cooling you can't beat the HAF-X case.
2. Lets talk about setting your computer on the floor. That is the least desirable place to set your computer. Especially if you have carpet. There must be some way to get it up off of the floor. Even if it is just six inches.
3. If L3 cache is important to you then you should consider the 3930. The 3930 has 12Mb and the 3820 has 10Mb. The 3960 has 15Mb but it is out of your budget. In fact the 3930 is probably out of your budget. The 3770 has 8Mb of L3 cache. Since you don't use multiple cores for your work you best choice may be the 3820.
Remember that the 3770, 3930 and 3820 would be operating at about the same frequency. That would be 4.5 to 4.7Ghz. The 3820 will be 4.4/4.5.
4. You need to decide about your monitor before you buy your system. If you move up to a 2560 resolution your build needs to be different. If you go with the Dell U2312 then one 670 2Gb FTW would do it as long as you don't go big time into gaming. SLI 670 2Gb FTW would be a good choice. You would need SLI 4Gb for the 2560 resolution.
Edited by FrankW - 18 Jul 2012 at 8:32am
Avatar
Digital Storm Live Chat Rep.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 9:26am
Hi RClive,
Just to add a couple of things.  If you go with the X79 platform either the 3820 or 3930 DS will require liquid cooling.  You could go with the Vortex 240, it is a sealed unit so no maintenance required.  You could still go air cooling for the rest of the components and the HAF X case is best for air cooling as Frank said.
Also the 3820 is not a K chip so DS will only OC it to stage 1.
I hope this helps and keep us posted.
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 11:12am
Hi Guys,
Thanks a lot for the input!
So X79 it is, Lets see if I can swing the 3920, otherwise I’ll go with the 3820 and then for cooling seems like the vortex 240mm.
On the case, there are severe space limitations. Currently my PC is underneath the desk. The space is 25” deep (with a panel that comes down 14” at the back) and about 27” of clearance height wise. This means that the top outtake fan at the back of the computer will have clearance issues, and not much room to raise the computer off the ground, 2-3”.
HAFX = 21.7" (H) x 9.1" (W) x 23.2" (D)
Any thoughts on the Corsair 500R or suggestions for other cases that are a bit smaller?
But I will go home tonight and see if there are other options.
On the monitor, have to admit that these were speculations, as it’s a future purchase. But searching the forums a bit it looks like there are a lot of good reviews for the Dell U2312. So I’ll stick with that.
Thanks again for all your help.
Clive
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 11:24am
Hi RClive......The 500R is a good case.  Smaller to help your situation and has a side panel 200mm fan to blow fresh air on the graphic card and mobo area.
The 650D is also very good.  It has a 200mm fan in front and another 200mm fan on top for some pretty good air flow.
Good LuckBig%20Smile
  Quote FrankW Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 12:49pm
Hi RClive,
If you put your computer under a desk that traps the exhaust air you will have a problem of the side fans taking in hot air. With the Vortex 240 the hot exhaust will be trapped under the desk also.   Most people put a stool or short table next to the desk and set the computer on that. You really need to think about this. You are buying a high performance computer and you can't treat it like a run of the mill computer. At the very least you should think about venting the desk and maybe a fan or two to move the air under the desk.
A good mid-tower is the Corsair 600T. Get it with the vented side and add a fan there. It has a 200mm front intake, a 200mm top fan and a 120/140 rear exhaust.
Edited by FrankW - 18 Jul 2012 at 12:50pm
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 18 Jul 2012 at 1:35pm
Hi Guys,
These are all good suggestions, I'll explore tonight. There is a possibility of putting it next to the desk. So lets see.
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 20 Jul 2012 at 1:55pm
After some checking on different possible placements, a position next to the desk is possible, but only after some major moving around, so for now it will go under the desk but definitely not directly on the carpet. I’ll find something to put it on and add a fan to keep the air moving under the desk.
Regardless it seems that a smaller case will work better for me. So I’ve looked into the 500R and 600t as well as the 650D.
They all seem nice with different features. I’m leaning to the 500R as it’s the most compact, but I saw the Ode Level 4 Review in the review section, which I guess is close to the spec that FrankW suggested, and it seems very nice as well. The 650D seems like it’s a higher quality case, but has no side fan. Not sure if this is crucial.
Clive
One question for all these cases: the Vortex 240, seems to be attached to the top panel with the fans as intake. Am I correct that for all 3 cases the only exhaust fan is on the back panel near the top? If so is that enough?
  Quote FrankW Quote  Post ReplyReply bullet Posted: 20 Jul 2012 at 2:38pm
Hi RClive,
I think you will find that the Vortex 240 is mounted at the top but it is blowing out, not in.
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 7:39am
Hi Guys,
I've made a few minor changes and will be talking to DS this afternoon to finalize order. Heres the config and thanks for your help!!
Clive
Total Price with Instant Savings: $2,554.00
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (White Finish) <b></b>
Motherboard: ASUS P9X79 DELUXE (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz <b></b>
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) <b></b>
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 7:45am
That build looks good to me.  I'd go for it.  Awesome
  Quote FrankW Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 7:55am
RClive, yes that is a great build.
Avatar
  Quote Asangard Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 11:23am
Really nice build and you even got the free T-Shirt. Cool
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 2:07pm
Thanks everybody!
So the order is made and I really enjoyed dealing with DS (Bryan) over the phone. The only change he suggested was to upgrade the CPU to I7-3930K, which I resisted. And of course I'm now agonizing over this.
And BTW its been great on the forum. It really made the whole process a lot more fun.
RClive
PS Never one to turn down a free T-Shirt
tju76 View Drop Down
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 2:36pm
You should be fine with the 3820 and the quad channel ram
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 24 Jul 2012 at 2:41pm
Yes, I agree.   There is a balancing act between budget and build and you'll be very happy with your rigs performance.
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 25 Jul 2012 at 1:15pm
Initial jitters gone, the choices were the right ones (thanks to your help) and am now watching the process unfold.
We're at Stage 5!
Meanwhile I'm thinking about how to optimize its new home and also how to not have a mess of cables behind it.
RClive
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 11:11am
Hi Guys,
The new computer came in the mail yesterday, and after carefully putting it up on a table so I could get a good look, I am completely floored. The quality of the work is beyond what I ever imagined. Plugged it in and it booted up without a hiccup. Will post a review with photos in a few days. Need to stop staring at it first.
Thanks again for all your help!!
RClive
Avatar
  Quote Asangard Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 11:27am
Hi RClive,
Congrats on your new rig.Cool  Looking forward to the pics and reveiw.  We love to see pics of new rigs.Big%20Smile
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 11:38am
Gotta see a pic of that 500R White case loaded with goodies.  Drooling
Avatar
  Quote RClive Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 1:43pm
Sorry to disappoint slightly, but at the last minute the White case morphed into the Black case. This after discussions with the significant other - cant understand why she didnt like the white.
But its still very nice looking.
RClive
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 1:46pm
Awesome either way.
Avatar
  Quote Asangard Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 5:30pm
I here wife points count a lot but hay I am not married so what do I knowBig%20Smile.
This page was generated in 0.1445313 seconds.
