1Yr old computer - Lag problem
Post Date: 2011-09-08
Utopi View Drop Down
  Quote Utopi Quote  Post ReplyReply bullet Topic: 1Yr old computer - Lag problem
    Posted: 08 Sep 2011 at 11:10am
The problem occurs when I either play a game or browse the internet and watch a movie on my other screen. Let's start with the specs.
HAF 932
CPU: Intel Core i7 930 @3.9GHz
MB: EVGA X58 LE Edition SLI (Intel X58 Chipset)
Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series
PS: 1200W Digital Storm Certified (Dual/Triple/Quad SLI Compatible)
Main HD: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition)
2nd HD: 1TB
GPU: 1x NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology)
Air Stage 1 Cooling Noctua dual fan 120mm
1 24" Asus monitor 1920x1200
1 23" Acer monitor 1920x1080
SO, there's my PC. I have 7-8Gig left on my SSD, everything else is on the second HD.
Now, when I'm on the internet and a movie playing on the smaller screen, whenever i load a page my movie starts lagging and the sound skips - all the time-
Same thing happens when I play game and watch a movie at the same time. I use Windows Media Player - full screen, and my game either in full screen or windowed. 1 of the 2 application is always windowed.
So please help me find what's happening. It wasn't happening before but it is happening for the past month or two.
I'm a little mad because the pc cost a lot of money and I tought it could handle 2 screen easily.
Thanks!
P.S. Anyone can explain to me why there's no HDMI port in the 480GTX??
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 08 Sep 2011 at 12:24pm
It's most likely a driver or software issue causing this. Try using the Windows System Restore utility to revert back to a time when you were not having problems. If that does not fix it, I would try to uninstall and reinstall the latest graphic drivers from NVIDIA. If that also does not resolve it, a fresh install of Windows might be the best solution.
  Quote Utopi Quote  Post ReplyReply bullet Posted: 08 Sep 2011 at 12:35pm
Tyvm!
varindia View Drop Down
Avatar
  Quote varindia Quote  Post ReplyReply bullet Posted: 15 Oct 2011 at 6:23am
Your hardware en-tensions are not matching(main HD and PS) as you primary configuration is bit older. You can refer some manual of the same. Use appropriate driver software
