2010 Digital Storm build has died, need advicePost Date: 2015-07-07 |
brewbush
Newbie Joined: 12 Feb 2010 Online Status: Offline Posts: 3 |
Topic: 2010 Digital Storm build has died, need advice Posted: 07 Jul 2015 at 2:14pm |
under 3K Expectations: A machine that will give me 6-9 yrs without thinking about upgrading. Usage: Photo editing with photoshop and a lot of gaming Special Needs: Nothing particular. Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z97-E (Intel Z97 Chipset) System Memory: 32GB DDR3 1866MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1000W SliverStone Strider Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Seagate) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x NVIDIA GeForce GTX 980 Ti 6GB (Includes PhysX) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler (High-Performance Edition) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 8.1 (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) So my current 2010 Digital Storm machine had a simple hard drive failure, so I decided I can repurpose it with a new hard dive somewhere else in my house. But since it is a little behind the time, an upgrade would be needed. I am looking for a system to last me 6-9 yrs without having to worry about graphic/cpu upgrades. My last one fit that spec, it was a 6gig, I7 920, Radeon HD 5870. Graphics I am thinking a single 980 Ti would be sufficient. I do not think I will be doing any 4K gaming for the considerable future, but that may always change. Motherboard, not really sure if I see a huge difference between the "best" ones, they seem to be similar to my untrained eye I picked the I7 knowing that it is not much better then the I5 in gaming performance, but with photo editing would it be needed? Thanks for your help. |
Quote Reply Posted: 08 Jul 2015 at 6:42am |
Hi brewbush.... Looks like a good built to me.
I would change the Seagate HDD to the Western Digital Black for another $19.. Better reliability and longer warranty. For editing, photo or video, or for multitasking, etc. the I7 with its hyper-threading will help . I'd stay with it. For gaming, not so much yet. The mobo is fine. If you don't see any features worth the added cost then you probably don't need them. A good sli board. If you're gaming on a 1920x1080 then even the 980 will play great. The Ti does give you more longevity and the higher vram helps with higher res monitors. If you don't plan on ever going sli, the the EVGA 750w SuperNova psu is all you need. The larger psu does give you the option, however. Hope this helps and good luck. |
