2600k First OC advice/Prob
Post Date: 2012-01-10
iCheck View Drop Down
  Quote iCheck Quote  Post ReplyReply bullet Topic: 2600k First OC advice/Prob
    Posted: 10 Jan 2012 at 2:33am
Hi everyone, This is the first time I'm OCing my system. Regarding the image above, I'm curious about my core voltage shown there. The CPU Vcore that i set for the BIOS is 1.340v but what is shown there is 1.284v. Is there a problem with my OC? or that is not the value I'm looking for? Please help. Thanks
Another thing is that I want some advise for my OC @ 4.8Ghz. What are the optimal vcore that I should have to achieve stability. Give me a range or reference vcore for me to start with. Thanks
Im using a i7-2600k with a Noctua NH-D14 cooler, 850W PSU, Corsair Vengeance LP pc3-12800 8GB.
  Quote iCheck Quote  Post ReplyReply bullet Posted: 10 Jan 2012 at 2:39am
This is Core Temp 1.0. With the same BIOS setting, I'm getting another different value for the VID which is 1.3611v on full load.(reminder- the value I set for the CPU core voltage is 1.340v). Can anyone help me? Do I have to disable something in order for the vcore to be stable? Thanks again
  Quote iCheck Quote  Post ReplyReply bullet Posted: 10 Jan 2012 at 4:29am
Omg There is something wrong with my OC. Why my idle vcore is higher than my full load vcore(shown in the CPU-Z)? Can anyone help?
Edited by iCheck - 10 Jan 2012 at 4:30am
Avatar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 10 Jan 2012 at 7:04pm
@iCheck, I don't mess around with oc settings here for a few reasons.
you can look at guides like this one if you like
your vcore is fine as long as you are below 1.4 but go back and read that guide and double check your work.
  Quote iCheck Quote  Post ReplyReply bullet Posted: 10 Jan 2012 at 10:36pm
The problem is I'm using a Gigabyte motherboard. Can you tell me which is the vcore that I should aware of? is it the core voltage in CPU-Z or VID in Core Temp?
  Quote iCheck Quote  Post ReplyReply bullet Posted: 10 Jan 2012 at 10:58pm
There is something different with the HWmonitor for asus and gigabyte. the vcore are stated with different names. With this OC i put the vcore to normal in the BIOS(i didnt put it at 1.300v). Is it ok?(since the vcore is around 1.284v to 1.300v) The guide didn't help much with my prob. Thanks
Edited by iCheck - 10 Jan 2012 at 11:02pm
Avatar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Jan 2012 at 1:46am
you check your vcore (core voltage) with cpu-z, and go with what it says, forget the rest, we use hw for temps. forget core temp.
This page was generated in 9.008789E-02 seconds.
