3DMark 11 problem (might be my system)Post Date: 2012-05-21 |
sbq
Newbie Joined: 10 Nov 2008 Online Status: Offline Posts: 60 |
Topic: 3DMark 11 problem (might be my system) Posted: 21 May 2012 at 9:21pm |
I've been having some BSOD and black screen reboot issues when playing certain games (Diablo 3, Tera) so I cleaned up some stuff from my system and installed the 3DMark 11 Basic to test my system, but when I run it I usually get a messed up screen like this:
Link because insert image doesn't like Dropbox Though some of the tests will run normally. I've got a GTX 580 and I'm running on a 27" Dell monitor at 2560 x 1440 resolution. I've posted on the Futuremark forums after searching for something similar but I have to wait for an admin to approve my post, and I'm terrible at waiting, so I figured I'd post here too. Here's my current setup: System Configuration: Chassis Model: Digital Storm 950Si Processor: Intel Core i7 Extreme Edition 965 3.2GHz (Quad Core) (OC'd to 3.85 GHz) Motherboard: ASUS P6T Deluxe (Intel X58 Chipset) (Supports Dual SLI or CrossFire) System Memory: 6GB DDR3 1600MHz OCZ (High-Performance) Power Supply: 1000W Corsair HX (Dual/Triple/Quad SLI Compatible) Hard Drive Set 1: Operating System: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed) Hard Drive Set 2: Multimedia\Data: 300GB Western Digital VelociRaptor (10K RPM) (16MB Cache) (Extreme Speed) Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) (LightScribe Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card(s): 1x nVidia GTX 580 1.5GB (not original to this config, was upgrade form 4870 X2 I got with this system) Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 3: High-Performance Liquid Chilled FrostBite System For CPU Chassis Airflow: Upgrade Chassis With Zalman Performance Fans Enhancements: LCD Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade) CPU Boost: Yes, Overclock the processor as much as possible with complete stability Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: Yes, Overclock memory frequency (Includes Memory Fan Kit Installed) Windows Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Now running Windows 7 Ultimate Edited by sbq - 21 May 2012 at 9:27pm |
sbq
Quote Reply Posted: 22 May 2012 at 11:36am |
Ran it again using a display scaling mode of stretched instead of centered and it's running fine.
