4K Build Please Help CheckPost Date: 2015-10-19 |
goodman247
Newbie Joined: 05 Sep 2010 Online Status: Offline Posts: 33 |
Topic: 4K Build Please Help Check Posted: 19 Oct 2015 at 10:36pm |
Budget: $4000-$4200
My last machine was also from DS purchased 5 years ago (SLI GTX 480) real ancient I know . Now I finally saved enough to buy a new machine. The machine will mainly be use for gaming (hoping to finally experience 4k gaming) and movies. I also hope this machine can be somewhat future proof (hoping to use it for 5+ years like the old one). In terms of overall longevity, should I go for the Noctua CPU cooler instead of the Corsair? Also, is there a huge difference between using DS certified rams compare to the Corsair ones (trying to save as much money as possible). Below is the config, Ticket#1302292: Chassis Model: Special Deal Hot Seller - Corsair Obsidian 550D Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS MAXIMUS VIII HERO (Intel Z170 Chipset) System Memory: 32GB DDR4 2800MHz Digital Storm Certified Performance Series Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (512GB Samsung 850 PRO) Storage Set 2: 1x SSD (512GB Samsung 850 PRO) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance) H20 Tube Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Graphics Boost: - No Thanks, Please do not overclock my video card(s) Memory Boost: - No Thanks, Please do not overclock my memory OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Thanks guys Edited by goodman247 - 19 Oct 2015 at 11:07pm |
Quote Reply Posted: 19 Oct 2015 at 11:00pm |
I assume this will be a desktop...the ticket number you have up there is an old laptop with dual 680M GPUs.
You can add additional storage if you want (or you can use drives you already have and save the money). Also, wait a little while for UltraHD Blu-ray drives to come to market. This has closed loop water cooling for the CPU and both GPUs, so it'll be maintenance-free and have good performance when gaming for long periods. Configuration URL: https://www.digitalstorm.com/configurator.asp?id=1302287 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Coridium Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS MAXIMUS VIII HERO (Intel Z170 Chipset) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD PCI-E Card (400GB Intel 750 Series) (NVM Express) (Extreme Performance) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (EVGA HYBRID Edition) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H110i GT - 280mm Radiator Liquid CPU Cooler (Extreme Performance) H20 Tube Color:- Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires High-End Motherboard Selection) Boost Graphics Card(s): Yes, Overclock the video card(s) as much as possible with complete stability Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Portable Gaming: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
db188
Quote Reply Posted: 19 Oct 2015 at 11:12pm |
here's the abridged advice: pick your case of interest and stick $1300-1400 worth (2x980ti's) of graphics in it. add a 1000w psu to power it and the rest of your system; get 16GB of system ram and a decent high capacity ssd (i.e. 1TB Samsung EVO) and you're good to go.
something like an Apollo level 4 comes in under $4k |
Aventum 3
db188
Quote Reply Posted: 19 Oct 2015 at 11:58pm |
in regards to the DS system ram: i'm not sure if the memory modules they get from various vendors support xmp or overclocking with these baseline (i.e. Corsair "value select" series) sticks, you'd have to confirm with DS, but i suspect not. i'm not really into overclocking memory, but i do like to set the xmp profile, so to be safe i'd choose the mid range memory line like the Corsair Vengenace LPX which supports XMP 2.0 if i were you.
here's an "Air version" Apollo:
Chassis
Chassis Model: Digital Storm Apollo Core Components Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) System Memory: 16GB DDR4 2800MHz Corsair Vengeance LPX (High-Performance) Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (1TB Samsung 850 EVO) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: AIR: Stage 2: Noctua NH-D15 (Extreme Performance) H20 Tube Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Chassis Fans: Upgrade All Fans to Corsair Airflow Performance Edition (Up to 6 Fans) Digital Storm TwisterBoost Technology Boost Processor: Stage 1: Overclock CPU 4.0GHz to 4.4GHz Software Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Accessories / Goodies Customer Care Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Aventum 3
