Advice on Broadwell-E buildPost Date: 2016-10-24 |
Author | ||
drfm
Newbie Joined: 29 May 2012 Online Status: Offline Posts: 52 |
Topic: Advice on Broadwell-E build Posted: 24 Oct 2016 at 12:49pm |
This will be my 3rd DS computer if it meets my needs.
Budget: Around $4500-5000 for computer and OS only Expectations: Fast, quite, reliable, stable, upgradeable system that will last me 5+ years at least Usage: Used for general computing, Adobe Photoshop, Adobe Premier (basically transferring old family movies to DVD), Encore, InDesign, Desktop publishing, accessing medical imaging and charts from home. Possible home music server. No gaming. Specifications: Sorry could not find what I need from the parts listed in DS configurator. From my research and reading this is what I came up with as a starting point. I'm looking at Broadwell-E i-7 6900K or equivalent Xeon. Motherboards ASUS Deluxe II or X99 E-10G WS, or equivalent Supermicro? The case should have front access to at least 3 5.25 drives, USB 3 ports. Nanoxia 5B or Corsair 750D or Fractal Design XL R2 meet needs. Case should be less than 23" tall to fit under desk. Multi-card reader (fits in 5.25" slot) Memory 32-64 GB high quality and speed depending on CPU. If Xeon then ECC nVidia GTX-1080 Intel PCIe 750 1.2 TB SSD or equivalent in speed and durability Couple of 3TB backup drives in RAID 1 for backup and data protection Couple DVD/BluRay read/write optical drives 1000 Watts power supply, Corsair or equivalent (silent and powerful enough that fans don't need to run!) Cooling: Not sure. Either Noctua NH D15 or slimmer design for RAM compatibility or water cooling like Corsair H-115i or equivalent I understand that DS can order the parts I need if they don't have them. I don't know how will that affect warranty. Advice and input are appreciated. |
drfm
Quote Reply Posted: 24 Oct 2016 at 7:04pm | |
Update
I tried a configuration https://www.digitalstorm.com/configurator.asp?id=1509224 Cases are limited to 10 options only. No 1.2 TB Intel 750 PCI SSD (DS used to have this in the configurator) No Noctua fans (DS used to have an option for it. The first computer I got from DS came with a Noctua fan). Maybe I need to build this one myself! |
Quote Reply Posted: 25 Oct 2016 at 4:17am | |
The packing is not the foam expanding anymore so the noctua was not staying still during shipping so they stopped offering it.
Change your cpu cooler to h115i. forget the noise package its pointless and waste of your money, if you want quiet you have to go with quiet fans. I would go with corsair ram here |
valod
Newbie Joined: 07 Oct 2016 Online Status: Offline Posts: 69 |
Quote Reply Posted: 25 Oct 2016 at 6:51am | |
for a Possible home music server, i recommend you get a nice WiFi DAC. this will do wonders for your music.
are you a doctor? |
drfm
Quote Reply Posted: 25 Oct 2016 at 8:25pm | |
Yes |
drfm
Quote Reply Posted: 25 Oct 2016 at 8:37pm | |
I read that the Corsair H115i has noisy fans. Can the fans be replaced? |
Quote Reply Posted: 27 Oct 2016 at 4:25pm | |
It can be loud but yes you can change the fans on it and most people do, but I would not worry about till I get the pc and see if I actually put enough load on it to push the fans to that extent.
valod
Quote Reply Posted: 27 Oct 2016 at 8:39pm | |
i knew it. i could tell because you got a doctors hand writing. |
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9459 |
Quote Reply Posted: 28 Oct 2016 at 12:37am | |
drfm
Quote Reply Posted: 29 Nov 2016 at 5:31pm | |
Took the plunge yesterday and ordered my 3rd DS system with Cyber Monday savings
$400 off 5 yrs warranty (a $199 value) No taxes Free shipping. Order Contents: - Digital Storm Desktop - Config ID 1536594 (Config # 1536594) - Quantity: 1 - Price: $6,044.00 - -- PROMOTIONAL LIMITED TIME BONUS DISCOUNT: $400 (Config # 1536594) - Quantity: 1 - Price: ($400.00) - -- PROMOTIONAL LIMITED TIME 2 YEAR WARRANTY UPGRADE ($199 VALUE) (Config # 1536594) - Quantity: 1 - Price: $0.00 - -- FREE NVIDIA Bundle - Watch Dogs 2 (Digital Code) (Config # 1536594) - Quantity: 1 - Price: $0.00 System Configuration: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (Black) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6900K 3.2GHz (8-Core) (Unlocked CPU) Motherboard: ASUS X99-E WS/USB 3.1 (Intel X99 Chipset) (Workstation Class) (Up to 5x PCI-E Devices) System Memory: 64GB DDR4 3200MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1500W Corsair AX1500i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) (Internal) Storage Set 1: 1x SSD PCI-E Card (1.2TB Intel 750 Series) (NVM Express) (Extreme Performance) Storage Set 2: 1x Storage (2TB Western Digital - Enterprise Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Graphics Boost: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Professional (64-Bit Edition) Recovery Tools: Factory Reset Feature + Windows Installation CD (Partition up to 50GB of Storage) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Sub-Total: $5,644.00 Tax (0%): $0.00 S&H: FREE Ground $0.00 Grand Total: $5,644.00 Can't wait to get the system. Needs fan upgrades and I was thinking about the new Corsair magnetic levitation technology with low noise, high static pressure and high air flow fans to replace the 2 inflow fans in front, outflow fan on the back and the radiators fans unless there is better and quitter fans out there. |
drfm
Quote Reply Posted: 02 Dec 2016 at 12:13pm | |
Computer build stuck at stage 1 for 4 days now! Digital Storm must be busy
Quote Reply Posted: 02 Dec 2016 at 12:16pm | |
They get crazy busy this time of the year, every year. It is possible it moved up a stage or two, but you just didn't get an update. It happens, but just a guess on my part.
drfm
Quote Reply Posted: 06 Dec 2016 at 12:33pm | |
Thanks. I just checked and 8 days later I am still at Stage 1. Must be really busy or they don't have all the parts in stock.
drfm
Quote Reply Posted: 08 Dec 2016 at 12:37pm | |
Finally reached Stage 3 albeit 9-14 business days for shipping!
drfm
Quote Reply Posted: 19 Dec 2016 at 8:15pm | |
Stuck on Phase 5 for 11 days now!
drfm
Quote Reply Posted: 28 Dec 2016 at 9:24am | |
It has been 30 days since I ordered. Maybe I need to cancel the order and look somewhere else. Very disappointed.
Quote Reply Posted: 28 Dec 2016 at 9:37am | |
I'd call them and see what's up. Not much we can do on the forums.
Good luck. |
Kyser13th
Newbie Joined: 25 Oct 2016 Online Status: Offline Posts: 62 |
Quote Reply Posted: 28 Dec 2016 at 12:34pm | |
Talk to Alex. He can get you an idea of whats going on and how busy they are. I ordered my system in Oct and I'm still waiting on my system, which just recently got to Stage 5. Also you cant count non-business days and holidays since they are normally closed on those days. So really you've only had 21 working days. You are well ahead of the power curve compared to my 40 days.
Nav
Quote Reply Posted: 28 Dec 2016 at 12:37pm | |
Looks like it just passed testing the past hour or so
drfm
Quote Reply Posted: 31 Dec 2016 at 5:00pm | |
Finally I got word the computer is at stage 7. Ready to ship soon. I'll guess it will be at my home next year. Happy New Year to all.
