Advice on cooling & moboPost Date: 2017-01-09 |
Jason5111
Newbie Joined: 09 Jan 2017 Online Status: Offline Posts: 2 |
Topic: Advice on cooling & mobo Posted: 09 Jan 2017 at 6:53pm |
Max $3,000 (tower only) Expectations: Play games at 60+ fps on high settings on 1440p monitor (likely 16:9 but also considering 21:9). FWIW, I'm looking at monitors with G Sync and at least 100hz. Usage: 100% gaming Special Needs: The computer will be installed in my home theater and connected to surround sound. My Questions: 1) Will the stage 1 air cooling be sufficient with the overlocking? 2) Should I be looking at an upgraded mobo for my use, or is the default one ok? 3) I'm also considering a 960 EVO instead of the 850, but from what I've read they don't always work as the primary storage/boot drive. Would it work ok in my setup? 4) Will the integrated audio on the mobo get me 5.1 or do I need a separate sound card to accomplish that? 5) If you have any other feedback, please let me know. Saved Ticket #: 1583821 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (Black) <br><strong></strong> Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170-E (Intel Z170 Chipset) (Up to 4x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Performance Series <br><strong></strong> Power Supply: 750W EVGA SuperNOVA <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (1TB Samsung 850 EVO) <br><strong></strong> Storage Set 2: - No Thanks <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 8GB (EVGA ACX 3.0) (VR Ready) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: AIR: Stage 1: High-Performance Copper Heat Pipe Cooler <br><strong></strong> HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair Airflow Performance Edition Fans <br><strong></strong> Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) <br><strong></strong> Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) |
Quote Reply Posted: 10 Jan 2017 at 8:47am |
Hi Jason5111.....
1. The air cooler should be fine for the stage 1 oc. 2. It's a good mobo. Only reason to change, upgrade it , is if there's something specific you need on another board. For most, it works. 3. I believe all Asus Z170 mobo will boot off the M.2. Problems I've heard of is if one sli's, but I haven't spent alot of time looking into it. 4. It's an 8 channel audio, so 5.1 should be good. Pretty standard on all but the most entry level boards. 5. Looks like a good build to me. |
Jason5111
Quote Reply Posted: 10 Jan 2017 at 10:17am |
Thanks! I appreciate the input!
Quote Reply Posted: 10 Jan 2017 at 12:41pm |
My pleasure.
