Another Monitor Question
Post Date: 2012-04-10
wkroll View Drop Down
  Quote wkroll Quote  Post ReplyReply bullet Topic: Another Monitor Question
    Posted: 10 Apr 2012 at 4:39pm
Comp specs, I52500k Nvidia 560ti 8gig of ram.
Considering everyone is recommending the Dell Utrasharps I am looking to buy the biggest size my current vid card can handle.
My current monitor is a DELL 2001FP about 6 years old 1600 X 1200, would it be worth upgrading? What size monitor could my video card comfortable push out graphics?
Recommendations?
Thanks,!
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 4:48pm
Hi wkroll...your setup could handle the 23" 1920x1050 resolution Dell UltraSharp U2312hm monitor or equivalent IPS.   Not sure wht you play but most games on high would look great.   Skyrim on Ultra would also work.
  Quote wkroll Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 7:37pm
Thanks, for the information. Mostly MMO currently playing SWTOR.
Minka View Drop Down
Avatar
  Quote Minka Quote  Post ReplyReply bullet Posted: 10 Apr 2012 at 8:54pm
Since your monitor is already an IPS, I'd say there is no reason to upgrade unless the picture quality seems to be poor compared to other monitors you've seen.
Gateway NV79
i3 M330 2.13GHz
4GB RAM
500GB HDD (OS)
140GB HDD
17.3" 1600x900
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 11 Apr 2012 at 5:34am
wkroll.....your setup will play those games real nice on the monitor you have and the 1920x1050 I mentioned.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 11 Apr 2012 at 5:52am
Hi wkroll,
I think it is time you move up to a new monitor. The 2312HM would be a good choice. You have old tech and the viewing angle is only 88 degrees. The 2312HM viewing angle is 178 degrees.
Now if money is tight you could stick with your old monitor but I think you will like the new one a lot better. It will be bigger, better back light and way better viewing angles.
stephantmi View Drop Down
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 4:15am
I have dual Dell U2711 (2560x1440) and am very happy with them... I would without hesitation recommend them to anyone.
Black Ops Slade
3930K @ OC'd to 4.2MHz
Rampage IV Extreme
1050W Corsair 1050HX
16GB DDR3 @ 1600MHz
120GB SSD Corsair GT
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
Dual Dell U2711 2560x1440
  Quote FrankW Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 5:05am
Hi stephantmi,
What GPU setup do you have with your dual U2711s? Do you game on both or do you just game on one monitor?
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 5:31am
I have the gtx 680 in SLI
Some single some dual depending on the game... Bf3, in dual...
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
tju76 View Drop Down
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 9:59am
what do you get for fps running bf3 on those 2 monitors, and what settings do you run ultra. also do you notice any lag etc because of the slow response time of the ips
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 12:11pm
Ultra settings, low 40's and I don't have any issues with the monitors
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 12:54pm
could you tell me what you get for fps on just one monitor running bf3. see i am up in the air between 120hz and an ips monitor. does it just look amazing the picture quality
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 5:03pm
Am on the road, will be back on Tuesday evening, I'll try and give you the update on Wednesday...
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 5:51pm
okay thank you very much
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 5:52pm
you have the exact same build that i am looking at lol except i want a 240gb intel 520 and different case.
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 14 Apr 2012 at 6:58pm
I wanted the Corsair 550D, but DS said it was too small for the ROG motherboard... I wanted the ROG so I can add another 680 down the road. The recommended that I switch to the 650D.
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 17 Apr 2012 at 12:31pm
Just tried one screen and the fps were approx. 150...
everything set to ultra
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
Avatar
  Quote stephantmi Quote  Post ReplyReply bullet Posted: 22 Apr 2012 at 5:42pm
What did you decide to purchase... I agree on the 240, should have gone for it...  found a nice feature that I didn't know was on the 650D, a hot swap sata 3 port, under a sliding door on the top.  Allows you to plug a drive to fast copy... or back up...
Black Ops Slade
Rampage IV Extreme
16GB DDR3 @ 1600MHz
2-1TB WD Black
Corsair H100 Liquid
2x SLI GTX680
This page was generated in 0.1328125 seconds.
