APC 1500VA Uninterrupted Power & Surge ConditionerPost Date: 2015-07-01 |
funeralpyre88
Groupie Joined: 04 Feb 2011 Online Status: Offline Posts: 170 |
Topic: APC 1500VA Uninterrupted Power & Surge Conditioner Posted: 01 Jul 2015 at 11:56am |
APC 1500VA Uninterrupted Power & Surge Conditioner - BR1500G
What is this? Is it just a fancy version of your average surge protector? I don't know too much about electricity and plug outlets and stuff like that. For my computer I'm planning on getting the 1200W Corsair AX1200i power supply. would this work well with that surge protector? Does this surge protector keep your computer running for a couple minutes even if there is a power outage so you can save your files? |
core i7-6700k @4.7 GHz
Predator 360 cpu&gpu 16 GB DDR4@2800 MHz ASUS Z-170 PRO GAMING 256 GB SAMSUNG 850 PRO 500 GB SAMSUNG 850 EVO GTX 980 TI ASUS STRIX ACER XB270HU 2560x1440 @144 hz |
hoserator
Quote Reply Posted: 01 Jul 2015 at 12:48pm |
Hi funeralpyre88,
It is a battery back up with an output capacity of 825 watts. It depends on the load on it as to how long it will keep whatever is hooked up to it powered. It has a little multifunction screen that will tell you the run time with what is hooked to it. The UPS's that will cover all 1200 watts are more expensive and you probably don't need them. If you ever get the two psu option you have to get two ups's, one for each. They are very handy if you have small power disruptions like we do in S. Fla whenever it rains and the tree branches ground out power lines. Edited by hoserator - 01 Jul 2015 at 1:02pm |
funeralpyre88
Quote Reply Posted: 02 Jul 2015 at 6:09pm |
What is the difference between the "Digitally-Controlled power supplies" and the regular ones? I feel tempted to get the 1200W power supply simply because its "digitally controlled".
