Apollo Build: Air or Water Cool 6700k
Post Date: 2016-11-22
gdead65 View Drop Down
  Quote gdead65 Quote  Post ReplyReply bullet Topic: Apollo Build: Air or Water Cool 6700k
    Posted: 22 Nov 2016 at 4:44am
In the process of building Apollo with concerns about reliability of water coolers.
Can the 6700k take the Air cooling option stage 1 with overclocking, or is it better to roll the dice with the h100i gtx cooler and keep a spare on hand for that day in the future.
Noise is not an issue for I game with headphones :)
build 1524556
thanks-
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Nov 2016 at 4:52am
That question has been asked a lot lately.   Without knowing exactly what stage 1 air they use, we can't say for sure. If it's still the Hyper 212 EVO, as in the past, then it can handle a moderate oc.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Nov 2016 at 5:03am
Couple of suggestions with your build....change the HDD to the Western Digital Black.   More reliable and longer warranty.
Change the 750 psu to the other for additional $34. Gold vs Bronze efficiency, longer warranty and fully modular wiring.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 27 Nov 2016 at 11:33am
Just know, 6700k's are hitting 4.7-4.8ghz on average with overclocks. I know you're only after stage one, but I guess the question is why? If you can get another half a ghz out of your cpu with stability for 24/7 use, why not?
I'm a fan of the Corsair AIO's personally. But I would worry about upgrading to the H100i or any variant of it if you're only going to be pushing like 4.2-4.3ghz. As bprat said, it's kind of difficult. There are only a select few air coolers I'd trust to keep my cpu cool if I'm planning on applying more voltage to it.
I'd get some form of an AIO if I were you, otherwise try to opt for a higher end air cooler. But that's just my opinion.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
  Quote gdead65 Quote  Post ReplyReply bullet Posted: 18 Apr 2019 at 1:28am
2 yr reveiw of H115i Corsair-
after two yrs of use on a 17 7700 k- the pump is starting to give me some hiccups. I think air / particulates are floating around the loop. Once in a while my temps start to climb aggressively (Pump RPM is good 3050-3100). I shut down, tap the Pump, shake the rig, reboot and all is good for a week or so. Rinse wash and repeat. When it works- it is a champ. idle 27c load 70c (running at stock speeds for now)
I have a Noctua 15-dhs sitting next to me for that inevitable day when this fails.
Apollo i7-7700 1070
Ordered: 2-12-17
Stage 1: 2-14-17
Stage 2 & 3: 2-16-17
Stage 4 & 5: 2-21-17
Stage 6: 2-23-17
Stage 7: 2-25-17
  Quote Cretae Quote  Post ReplyReply bullet Posted: 19 Apr 2019 at 5:12am
In a year and a half I've been back around here, this is the first review I've seen of an AIO cooler. Thanks for the input.
The Corsair AOIs come with a 5 year warranty from Corsair if you're interested.
  Quote gdead65 Quote  Post ReplyReply bullet Posted: 19 Apr 2019 at 2:07pm
Just my experience so far:
I will Warranty this when it fails and it will become my backup. I will going back to air (noctua d15s). Im spending too much time deducing what could be occurring. DS does such a good job at cable management in their rigs that replacing will be a bit of a PITA (that's a compliment to you guys). I wish I could see inside the tubes to figure out what was going on
My OCD has me always monitoring temps. Call me crazy but Every change in fan speed pitch I check Temps.
>some days: Runs like a dream. 24 idle- 60 stressed- water temp 33
>Some days: Heat creeps: 50 idle - 80 stressed Water Temp 38c and climbing ( I shut down and shake rig tap pump and all is good again).
> If I restart multiple times- heat climbs (bubbles caused by cavitation?)
seems like blockages are occurring for the RPM of the pump is reported as 300-3150rpm always( in performance mode). I just don't know what particles could be floating around.
Edited by gdead65 - 19 Apr 2019 at 4:25pm
Apollo i7-7700 1070
Ordered: 2-12-17
Stage 1: 2-14-17
Stage 6: 2-23-17
Stage 7: 2-25-17
