Apollo Case QuestionPost Date: 2016-11-15 |
Saad0612
Newbie Joined: 23 May 2016 Online Status: Offline Posts: 24 |
Topic: Apollo Case Question Posted: 15 Nov 2016 at 10:11pm |
Hey all
This might be kind of a weird question but exactly how many fans are in the Apollo desktops? Thanks! |
Quote Reply Posted: 15 Nov 2016 at 10:54pm |
the case comes with 2 front fans and one exhuast fan, you can add fans to the top but most times that is where your cooler goes so thats about it, I think there is room on the bottom for one more.
Saad0612
Quote Reply Posted: 16 Nov 2016 at 9:18pm |
That's great!
Also will the ASUS Z170 Pro Gaming motherboard be be able to handle the 3 case fans and the Corsair H110i GT along with its 2 fans? |
Quote Reply Posted: 16 Nov 2016 at 11:15pm |
You can chain fans together, short answer yes it can, but the fans for the cpu cooler connect as one and have a different head, the 3 case fans are not connected to the mobo and you want your case fans running full speed anyways, also if you want less possible headache go with h115i, otherwise you can't say I didn't tell you.
Saad0612
Quote Reply Posted: 17 Nov 2016 at 5:59am |
Alright thanks!
Also is the H110i GT unreliable or not good for you to not recommend it? |
Saad0612
Quote Reply Posted: 17 Nov 2016 at 1:04pm |
Oh and just one more thing, can I actually control the speed of the case fans? Like you said that it's better to have them on full blast meaning they'd be pretty loud. So I just wanted to clarify if I can actually manually control them WITHOUT the digital storm software.
Edited by Saad0612 - 17 Nov 2016 at 1:04pm |
Quote Reply Posted: 17 Nov 2016 at 2:31pm |
The Apollo , Corsair 760T, has a 2 stage fan control on the front panel the case fans will be plugged into.
You can also unplug the connectors from the fan control after removing the right side cover, then plug them into the motherboard fan control headers. In Bios or using the Asus fan control software you can adjust their speed. |
