Apollo or Velox and Hydrolux question?Post Date: 2016-02-05 |
Moritsuna
Newbie Joined: 31 Jan 2016 Online Status: Offline Posts: 52 |
Topic: Apollo or Velox and Hydrolux question? Posted: 05 Feb 2016 at 4:14pm |
So I see on the site the apollo and velox are advertised with the hydrolux cooling system and they look great, but I am not sure about getting a standard apollo without hydrolux and no lighting. Would it be kind of drab then having a big window and nothing to show off on the inside?
Would you suggest the DS coridium case instead for those not interested in getting hydrolux? Also: If I purchased Hydrolux is it worth the cost? I have noticed that ALL of the prebuilt apollo and velox don't come with hydrolux standard, when all the pictures show with it equipped. I can probably get the Hydrlox lite that cools just the CPU, and I am guessing you don't need the GPU cooler as well without overclocking the GPU? Edited by Moritsuna - 05 Feb 2016 at 4:22pm |
db188
Quote Reply Posted: 05 Feb 2016 at 4:28pm |
there's all kinds of ways you can customize your rig, it just depends on what your priorities are.
if you only need one color lighting, you can have them install a mono-colored LED light strip or two. or you could have them do the full RGB remote controlled unit they advertise. i wouldn't jump to the expense of a full custom water loop if i wasn't intending to push the performance of my system with a lot of high overclocking. form over function isn't my thing, although form AND function is. a full custom water loop offers the highest potential cooling-to-noise solution possible, but most systems don't need it. you can get by on top end air or AIO water coolers for low-moderate overclocking. |
Aventum 3
Moritsuna
Quote Reply Posted: 05 Feb 2016 at 4:39pm |
Okay, lighting isn't my priority then haha. I'm guessing the coridium would be better then.
Looks ok? Chassis Model: Special Deal Hot Seller - Digital Storm Coridium Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 750W EVGA SuperNOVA (750 B1) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) Graphics Card(s): 1x NVIDIA GeForce GTX 980 4GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 240mm Radiator Liquid CPU Cooler HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: Asus 24 inch VG248QE Series (144Hz Refresh Rate) (1ms Response Time) (1920x1080) Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
