best monitor/ speaker system
Post Date: 2012-06-10
stormswa View Drop Down
  Quote stormswa Quote  Post ReplyReply bullet Topic: best monitor/ speaker system
    Posted: 10 Jun 2012 at 7:01am
not exactly sure of my desk size, like the opening I have to put a monitor will check that tomorrow. Im going to be running 2x 670 gtx sli in my system so what is some good suggestions for monitors. I would like to keep it under $500 if I can for the monitor but I want it to look goooooooood. I already know keyboard im getting its about $150, and mouse is I think around $40. Want to stay around 1k so that leaves about $300 for speaker system so also what are your suggestions on the speakers? all this will be bought in the month I have to wait for computer to be sent to me.
Edited by stormswa - 10 Jun 2012 at 7:01am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 10 Jun 2012 at 9:55am
A couple of monitors to consider would be the U2312HM Dell UltraSharp and Asus PA238Q 23" monitor.   Both IPS,  which means nice color and clarity.
The sli 670's will max out almost everything on the 1920x1080 resolution they have.
Edited by bprat22 - 10 Jun 2012 at 9:55am
  Quote stormswa Quote  Post ReplyReply bullet Posted: 10 Jun 2012 at 11:36am
Yea I wanted to go higher then 1920x1080, I know these babies can handle higher resolution
Bronwen View Drop Down
  Quote Bronwen Quote  Post ReplyReply bullet Posted: 11 Jun 2012 at 8:40am
I have the HP 30" IPS monitor and it works great. If i was to replace it i would go with the Dell 30". 2560x1600 is pretty sick. ;) I use a pair of bose computer speakers and they work pretty good for me.
