I have tried this myself, and personally is really does work it just depends on your internet connection speed.
by: MatthewHSE as published on WebmasterWorld It's
been awhile since I first posted a few simple tips on how to speed up
Firefox performance. Some of the information is outdated, so I thought
a recap might be a good idea.
All
of these tips can be implemented by anyone who knows how to use their
keyboard and mouse. No advanced knowledge is required. With that said,
however, the adjustments we'll be looking at can have adverse effects
when visiting certain websites. I'll note possible concerns with each
tip so everyone can decide for themselves if that particular tip is for
them. Each of these will help speed up Firefox, independently of the
others, so don't feel like you have to use all of them if you don't
want to.
To start your tweaking, type about:config
in your Firefox location bar. This will bring up a list of hundreds of
preference settings. All the changes we'll be making can be done here.
Use the filter bar just above the list of preferences to "drill down"
to the preferences you need. There are Firefox extensions
that will allow you to change most of the settings we'll be talking
about in more of a GUI environment, but I prefer to do it in about:config
since installing extensions can tend to have a hit on Firefox performance.
http://www.webmasterworld.com/forum119/445.htm
So on to the actual preferences you'll need to set. To change a preference, double-click it and enter the new value.
network.http.sendRefererHeader
- This setting controls whether or not Firefox will send a "referer
header" for the pages and files it requests. Sending the referer header
takes time, actually more time than you might think. Turning it off can
improve your browsing
speed quite a bit. The default for this one is '2', which means Firefox
will send the referer header for page requests AND for images. Set this
preference to '1' to send a referer header for page requests only (faster), or to '0' to not send referer headers at all (fastest).
WARNING:
Disabling the referer header can cause some websites not to work
correctly; for instance, Buy.com requires the referer header during the
checkout process. Only set this preference to '0' if you think you'll
recognize related problems if/when they occur. I can't imagine any
problems that might be caused by setting this preference to '1' (send
referer header for page requests only) and that should improve
performance dramatically on most websites.
TIP: The excellent Web Developer
extension allows you to enable or disable referer headers with just two
clicks. This option is listed under the "Disable" menu on the Web
Developer toolbar.
network.http.pipelining
- Enabling pipelining allows Firefox to request files (such as images,
external CSS and Javascript files, etc.) at the same time instead of
individually. The default for this preference is FALSE. Double-click it
to set it to TRUE. Enabling pipelining is one of the biggest ways to
boost your browsing speed, provided you have a high-speed connection. Pipelining on a dialup connection may have a less noticeable effect.
WARNING:
Pipelining is not well-supported (at all?) on Microsoft web servers.
Most of the time everything will still work fine; however, some rare
websites (most notably Adobe) that are hosted on Microsoft servers will
slow to a crawl if you try to browse them with pipelining turned on. I
have only run into this on about three or four occasions in over two
years of surfing with pipelining enabled; still, it pays to know the
symptoms so you can temporarily disable pipelining if you need to.
network.http.pipelining.firstrequest
- As the name implies, this setting (supposedly) controls whether or
not Firefox pipelines the first request for a pageview. I don't see
what real-world difference this setting can make, but I always set it
to TRUE anyway, just in case. The default is FALSE.
WARNING: The comments above about pipelining may also apply to this setting - or maybe not. I honestly don't know.
network.http.pipelining.maxrequests
- This is the maximum number of concurrent requests Firefox is allowed
to make. I used to recommend setting this to a high value, around 32 or
so. I have since found out that this can have serious implications for
web servers that may get overloaded trying to respond to so many
requests all at the same time. I don't have any statistics on what a
good upper limit for this setting would be, but I have mine set to 16
which seems to work well (possibly better than 32 in the first place).
From what I've heard, I would not try setting this higher than 16.
Depending on your connection speed, you may have better success setting
this to an even lower number.
WARNING:
Setting this too high may set off security triggers on some web servers
and could get you banned from some websites. Keep it to a reasonably
low number in the interests of courtesy and convenience to website
operators.
network.http.proxy.pipelining
- If you're behind a proxy, you may want to set this value to TRUE as well. Default is FALSE.
WARNING:
I'm not sure if any proxies would have problems with pipelined requests
or not. Maybe someone who knows more about proxies could comment on
this.
nglayout.initialpaint.delay
- This preference doesn't exist by default, so you'll have to create it. Right-click on some whitespace in about:config
point to New, then choose Integer. Enter a number between 0 and 1000
(or more if you like, but I don't recommend it) then click OK. This
setting stipulates how many milliseconds Firefox waits to start
rendering a page after it starts to receive data. The default behavior
is 250. I usually set mine to 0, meaning Firefox will start rendering
the page with no delay at all. This provides near-instant feedback
while browsing.
Setting this preference to a higher number - 250 (default), 500, 1000,
etc. - will allow Firefox to download more data before it starts to
render the page. Some people prefer to set this to 1000 or so, which
will give a one-second delay before the page starts to render, but will
usually render the entire page all at once in the blink of an eye. Try
several settings and see how you like it best. Setting the delay to 0
may actually slow down browsing
slightly, but gives an illusion of speed since the rendering begins
immediately. Setting a long delay doesn't give feedback so quickly, but
you get the whole page all at once instead of in chunks, which seems faster to some people.
WARNING:
Setting this value below 250 may cause minor rendering problems on some
table-based websites. This usually is not a problem, normally being a
minor inconvenience at worst.
browser.cache.memory.enable
- This preference allows Firefox to cache pages and files in memory,
which can allegedly improve performance with the back and forward
buttons. I've never noticed a difference myself, but I imagine mileage
will vary on different systems. Default is TRUE so you probably don't
need to change this one.
browser.cache.memory.capacity
- Only used if the above setting is set to TRUE. This setting controls
how much memory Firefox is allowed to use for caching purposes.
Supposedly, setting this to a higher number can improve performance,
provided you have enough free memory in the first place. Again, I've
never noticed a difference from this.
- A Note on the Cache:
Firefox tends to slow down a bit as your cache (disk cache, not memory
cache) nears its capacity, particularly if you're using a higher than
average cache size. Clear your cache periodically to avoid this
performance hit. I use the Clear Cache Button
extension, which gives a toolbar button to quickly clear the browser
cache. (This can also be useful for developers who need to be sure
they're viewing the most recent version of a page but don't want to
disable the cache entirely.)
