Build advicePost Date: 2016-02-18 |
Demonic
Newbie Joined: 12 Sep 2011 Online Status: Offline Posts: 8 |
Topic: Build advice Posted: 18 Feb 2016 at 9:02am |
My budget is around $5K.
Wanting to run on best settings possible with single monitor. I plan on using this comp for gaming (Skyrim/Fallout 4/Diablo 3 type games), some streaming and internet surfing. special needs : dusty environment what I've got so far Configuration Code: 1363704 Total Price with Instant Savings: $4,902.00 Direct Load URL: https://www.digitalstorm.com/ Specifications: Chassis Model: Special Deal Hot Seller - Hailstorm II Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Corsair Dominator Platinum DHX (Extreme-Performance) <br><strong></strong> Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) Storage Set 1: 1x SSD (1TB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-N53 (Dual Band Performance) (Supports 802.11n/g/b) <br><strong></strong> Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only) HydroLux Tubing Style: - No Thanks HydroLux Fluid Color: Red Tubing (Requires Custom HydroLux Liquid Cooling System) Cable Management: - No Thanks, Please do not overclock my memory Chassis Fans: Corsair LED Airflow Performance Edition (Red) (Up to 6 Fans) Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks <br><strong></strong> Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks What's a good monitor to go with this build? Also what changes should i make? Thanks in advance! |
eeekman
Newbie Joined: 06 Oct 2015 Online Status: Offline Posts: 95 |
Quote Reply Posted: 18 Feb 2016 at 7:23pm |
I'm using the excellent Acer XB270HU. 2560 x 1440, 144Hz, Gsync.
(I think the current version is XB271HU). Gaming is excellent. Picture is vibrant. Beautiful monitor. Cost me $700 though. |
Aventum 3
i7-6700k @ 4.6GHz 32gb 3200MHz RAM Gigabyte Auros Waterforce Extreme 1080ti |
FrankW
Quote Reply Posted: 19 Feb 2016 at 9:46am |
Hi Demonic,
That is a nice build. I have put together an alternate build for you consideration. The big difference with my build is a different case and both GPUs and the CPU are water cooled. I have also added a fan controller system and a lighting system with multiple colors. You pick the color you want to use. The cooler system that is used has a 360 rad and should fit at the top of the Apollo case. I also picked a black case but a white case is also available. I included a level one Overclock. I changed your SSD from the EVO to the newer and better performing M2 Samsung 950 SSD. This will give you faster performance and is mounted on the motherboard. It is a NVME drive but only 512Gb. This build is intended to give you some options to consider. Personal preference always plays a part in your choices. Since we are under budget you might consider increasing your warranty a year or two. The standard warranty only gives you one year of parts replacement. Frank Configuration Code: 1374552 Cost: $4817 Configuration URL: https://www.digitalstorm.com/configurator.asp?id=1374552 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (Black) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: - No Thanks Optical Drive: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (NVIDIA GeForce GTX 980 Ti 6GB (ASUS Strix Edition) (VR Ready) Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (2x Graphics Cards + CPU) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair LED Airflow Performance Edition (Red) (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) Edited by FrankW - 19 Feb 2016 at 9:50am |
eeekman
Quote Reply Posted: 19 Feb 2016 at 10:30am |
FrankW makes some good recommendations.
The Samsung 950pro is an awesome SSD and water cooling the GPUs will allow you to get more FPS out them than they already produce. Demonic just check that FrankW didn't include wireless internet in his config, not sure if you needed it. Edited by eeekman - 19 Feb 2016 at 10:30am |
Aventum 3
Demonic
Quote Reply Posted: 19 Feb 2016 at 1:32pm |
Thanks for the advice on the monitor. That wireless card was optional can settle for a usb one.
@FrankW thanks a lot for the advice! You're set-up is probably what I'll go with. |
db188
Quote Reply Posted: 21 Feb 2016 at 4:25pm |
a little advice regarding your internet setup: use some of that dough to upgrade your wireless (unless you're going to be plugged in via ethernet). stay away from USB wireless dongles (they're all junk). get yourself a good AC1900 dual band router from Asus or TPLink and pair it with the same wireless card from either of those two vendors.
Aventum 3
