Build advicePost Date: 2017-04-20 |
Rborr14
Newbie Joined: 20 Apr 2017 Online Status: Offline Posts: 1 |
Topic: Build advice Posted: 20 Apr 2017 at 6:57pm |
Hi all. My old digital storm pic has lasted me about 6-7 years now. Blue screen of death, figured I'd get a new one than deal with upgrading since it's been so long. With this build anything I should change because it won't work or anywhere I can save some money you think??
Budget: 2-4K Expectations: Coming from an sli and overclocked pc that lasted a long time with no upgrades. Would like to get a rig that lasts and allows me to be hands off. One complaint I have with old set up was the noise. Would like to reduce noise as much as possible. Usage: Gaming and casual use. FPS and various other games. Special Needs: None really. Saved Ticket #: 1650203 Specifications: Chases - corsair carbide quiet 600q Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7-7700K 4.2 GHz (Codename Kaby Lake) (Unlocked CPU) (Quad Core) Motherboard: MSI Z270 GAMING PRO CARBON (Intel Z270 Chipset) (Up to 3x PCI-E Devices) System Memory: 32GB DDR4 3000MHz Digital Storm Performance Series Power Supply: 750W EVGA SuperNOVA (750 G3) (Fully Modular) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (480GB Digital Storm Performance Series) Storage Set 2: 1x Storage (2TB Seagate / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-AC68 (Supports 802.11ac) <br><strong></strong> Graphics Card(s): 2x SLI Dual (GeForce GTX 1080 Ti 11GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stock Factory Turbo Boost Advanced Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 50GB of Storage) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year |
Quote Reply Posted: 21 Apr 2017 at 2:22am |
Hi Rborr14. Welcome to the forums.
What monitor resolution are you using ? That determines the graphics card needed. If you stay with sli then I would bump up the psu. Drop the 32gb ram 16gb, more than enough for gaming. I would also select the CD under Recovery options. Good to have if the drive dies. The rest looks good. Edited by bprat22 - 21 Apr 2017 at 3:08am |
