How to fix loose shoes quickly?
Post Date: 2018-05-03
Jardenblack26 View Drop Down
  Quote Jardenblack26 Quote  Post ReplyReply bullet Topic: How to fix loose shoes quickly?
    Posted: 03 May 2018 at 8:31am
For several reasons, your shoes are wide. This makes movement more difficult and affects the health of the feet. However, not everyone knows how to fix loose shoes quickly and effectively. So, immediately following the article that Smart men summarize below!
The harm of wearing loose shoes​
How to fix loose shoes when using shoes is essential. Because using loose shoes harms health as well as movement, workwear brand.
Specifically, wearing loose shoes will cause the following harm:
Shoes that are larger than foot size will feel uncomfortable.
You can even stumble while moving. That is why your feet will be sore, especially when you move a lot.
Wearing loose shoes causes the foot to suffer some injuries such as aches, sprains, dislocations,... Because the toes have to use force to try to keep the shoes while moving.
Also, you will feel less confident and lose focus on the shoes.
In addition to the above harms, if you use a pair of loose shoes, it also detracts from the aesthetics. Therefore, you should choose for yourself a pair of shoes that fit your feet or overcome the problem of shoes being wide.
How to fix loose shoes?​
Some ways to overcome the problem of loose shoes with quick results you can apply as follows:
Wear extra socks - How to tighten shoes
When wearing loose shoes, you can also handle them with plenty of socks. You have the option of wearing two or three pairs of socks at once if the shoes are too wide. When the shoes don't get too wide, just use thicker socks.
With this solution to wear additional socks, suitable for sports shoes, boot shoes,... When using it, you should pay attention: The socks cover the feet, so when using it is easy to confuse, so Use should be limited in hot weather.
Also, you should choose socks that are well ventilated and absorbent. This will help your feet stay dry and limit sweat production that causes discomfort.
How to handle large shoes with logo pads
Using logo pads is one of the simple solutions for wide shoes that you can apply.
In addition to making the shoe more fit, the use of logo stickers also works to reduce the friction between the heel and the shoe. This helps the back of the heel not hurt, even wearing shoes all day.
The logo is very thin, so you should only apply this method when the shoe is reasonably wide, safety workwear. Besides, the tape is easy to peel off, so this is not a safe solution when using shoes all day.
Put more paper in your shoes
How to insert more paper into the shoe is suitable for shoes with excess length. The pieces of paper fill the space inside to create a comfortable, comfortable fit when the feet are worn. However, when applying this wide shoe treatment, keep in mind:
Not recommended for wide-width shoes.
Do not do this if you are traveling all day, as the paper that causes rubbing can cause scratches and soreness in your feet.
When foot sweat is secreted, the paper is not able to absorb and release air, so it feels uncomfortable to use.
Using paper is an instantaneous solution to wide shoes, if you use shoes regularly, you should choose and apply them differently.
How to fix wide shoes with shoe insoles?​
One way to fix loose shoes that are effective and that are pretty much you are to use more insoles. These insoles will add more fullness to the foot and limit space in the shoe. How to fix with pads creates discreetness. Besides, in some cases, it also helps you improve your height.
Note when applying the remedy for wide shoes using the insoles are:
Should choose shoe insoles equivalent to the size of the shoe (in the standard shoe size table) to avoid redundancy or lack of pain when using.
Opt for shoe insoles that are soft, light, and sweat-absorbent for comfort all-day travel.
Besides, after each use, you should remove the pads and leave them in a dry, workwear clothing, cool place to increase longevity as well as prevent bacteria from developing causing bad odors.
Edited by Jardenblack26 - 11 Jun 2021 at 6:25am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 May 2018 at 2:11pm
Pretty sure the mobo can run 2 gtx 1080 , non sli, but the second pciex16 slot only runs , wired, at x4 bandwidth, instead of x16.    Much less performance on the second card.   How that effects folding I couldn’t say. Another member, DST4ME, used to fold for years but he hasn’t been around the last couple of months.
If you’re gonna run it hard 24/7, the Slate, being a closed box , might not be the best pick.   You want good airflow, if not having the video card on water.
