Build HelpPost Date: 2016-10-03 |
flllyi
Newbie Joined: 24 Jun 2010 Online Status: Offline Posts: 28 |
Topic: Build Help Posted: 03 Oct 2016 at 7:12pm |
Got a build here. Just wondering if you guys could give me some advice. How does the build look. Is it compatible. Will everything fit in the case. Do I need stronger PSU? let me know thanks alot :D
Corsair Carbide Series 100R Mid Tower Case EVGA superNOVA 750 B1, 80+ Bronze EVGA GeForce GTX 1070 SC GAMING ACX 3.0 EVGA Z170 FTW Intel Socket LGA-1151 Intel Core i5-4690K Processor 3.5 GHz 1151 Crucial Ballistix Sport 16GB Kit Samsung 850 PRO Cooler Master Hyper 212 Evo Thanks alot :D |
Quote Reply Posted: 03 Oct 2016 at 9:58pm |
What is the pc for?
flllyi
Quote Reply Posted: 03 Oct 2016 at 10:54pm |
Gaming
Quote Reply Posted: 03 Oct 2016 at 11:03pm |
OK give me a little more info, what res will you be gaming at? is it only for gaming? are you building this yourself? I assume you are trying to save as much money as possible?
Edited by DST4ME - 03 Oct 2016 at 11:04pm |
flllyi
Quote Reply Posted: 04 Oct 2016 at 1:22pm |
Sure - I am building this for myself. I will be gaming at 1080 - but may be going to 1200 soon. I only really want it for gaming and just general other use... Internet , maybe some Netflix stuff like that.
Quote Reply Posted: 04 Oct 2016 at 3:02pm |
Ok great, I think I almost have all the info I need, but one question, I'm not sure if we are on the same page on the resolution.
when I say 1080p we are talking 1920 × 1080 , next one up is 1440p ( 2560 x 1440), basically the last number is the referred to as the res, since it makes the biggest difference. So I'm confused when you say you maybe going 1200, are you referring to 1600 x 1200? or is it something different? Do you know how to and are you going to be ocing this cpu? Edited by DST4ME - 04 Oct 2016 at 3:03pm |
ArkansasWoman777
Quote Reply Posted: 04 Oct 2016 at 3:37pm |
there are monitors out there with the resolution 1920x1200 |
Quote Reply Posted: 04 Oct 2016 at 4:26pm |
Ya I know but that is not moving up from 1080p, that is just wide screen res. 1920x1200
Edited by DST4ME - 04 Oct 2016 at 4:27pm |
flllyi
Quote Reply Posted: 04 Oct 2016 at 6:54pm |
Yea - 1920x1200 - - I will not be overclocking
Quote Reply Posted: 04 Oct 2016 at 7:34pm |
ok then last question budget?
flllyi
Quote Reply Posted: 04 Oct 2016 at 8:46pm |
1300
Quote Reply Posted: 04 Oct 2016 at 8:57pm |
Ok For that budget why not go with a 6700K? you can have great power for a few years to come. If you want I can help you pick a few parts for it, and it will be under your budget.
As for your config, for a price of a 4690k you can get a new better cpu. the 4960 is socket 1150 the mobo you have chosen is socket 1151, not sure why you have the 4690 as 1151 its not. There is more but let me know which direction you want to go, new tech under your budget or the old tech (4690k) and we will go that route. |
