chassis Corsair Carbide Quiet 600QPost Date: 2018-05-15 |
carey
Newbie Joined: 15 May 2018 Online Status: Offline Posts: 5 |
Topic: chassis Corsair Carbide Quiet 600Q Posted: 15 May 2018 at 9:53pm |
The "Slade" desktop model photos shows a mesh screen in front of the fans. Exactly how do I find and get to this screen to clean it?
Quote Reply Posted: 16 May 2018 at 1:52am |
The front panel has 3 clips on the inside of each side. Push to remove, then the panel pulls off. The side covers are removed to get to the clips.
Hope this helps. |
carey
Quote Reply Posted: 16 May 2018 at 4:27pm |
Easier said than done. There's 4 clips on each side. Three of them were near impossible to undo, one because cables were in the way, and two because there was barely enough room to squeeze a finger in between parts of the chassis. Additionally, the fit around the two drives in the externally accessible drive bays were so tight I had to pry it off. To get it to go back on I had to file down the plastic of the drives' face plates slightly. -- Thanks for the post, that at least let me know it should be possible.
Quote Reply Posted: 17 May 2018 at 2:01am |
Thanks for the feedback. Might help others.
Never could figure out why Corsair would make their front panels so difficult to remove. It’s like that on a number of their products. |
