Configuration for 3D and 2D Concept DesignPost Date: 2016-12-31 |
Peerus
Newbie Joined: 31 Dec 2016 Online Status: Offline Posts: 1 |
Topic: Configuration for 3D and 2D Concept Design Posted: 31 Dec 2016 at 11:59pm |
[Around 3k] Expectations: [Photoshop, Maya, Zbrush, KeyShot. Often run simultaneously. Also used for basic gaming. I run a 2k asus monitor, and a 24hd cintiq] Usage: [Runs most of the day, runs multiple softwares simultaneously, used for 3d rendering, 2d editing and basic gaming] Special Needs: [I live in a hot dusty place, i look for durability and good thermals] Thank you in advance! I'm hoping to find out more about how to optimize hardware for my needs and digital design pipeline. Cheers, Peerus |
Quote Reply Posted: 01 Jan 2017 at 3:09am |
Hi Peerus... I haven't looked into those programs in some time, but my understanding is that the more cores, at a higher clock speed and lots of ram is what is needed. You probably know better than us. The gtx 1080 is for your gaming at 2k. The 1070 will also game on the 2k, but heavier shooters would appreciate the stronger card. Depends what you expect.
Configuration Code: 1576959 Total Price with Instant Savings: $3,032.00 Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1576959 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (White) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6800K 3.4GHz (6-Core) (Unlocked CPU) Motherboard: ASUS X99-A II (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 32GB DDR4 3000MHz Digital Storm Performance Series <br><strong></strong> Power Supply: 750W EVGA SuperNOVA <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (500GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 8GB (EVGA ACX 3.0) (VR Ready) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance) <br><strong></strong> HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled LED Lighting System (Multiple color options and lighting effects) <br><strong></strong> Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 50GB of Storage) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) See what you think and hope this helps. |
