Configuration HelpPost Date: 2009-12-01 |
ethorn
Newbie Joined: 01 Dec 2009 Online Status: Offline Posts: 3 |
Topic: Configuration Help Posted: 01 Dec 2009 at 6:28pm |
Hi, I am planning on purchasing a DS computer primarily for gaming. I mostly play iRacing and FSX. I use a resolution of 3840x1024 using Triple Head 2Go.
I will be using two 8800GT videocards until the Fermi comes out next year. At that point, I will probably purchase a single card as this should be adequate for the games I play.
My budget is ~$2000-2300.
Here is my config:
Ticket# 359688
Chassis Model: Cooler Master HAF 932 (Black OPS Edition)
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested) Power Supply: 750W Digital Storm Certified (Dual SLI Compatible) (Silent Edition Recommended) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: - No Thanks, I will be installing my own video card(s) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 1: Noctua Dual 120mm Fans High Performance Cooler (Compatible With ONLY i7 Processors) H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: Noise Suppression Package (Optimized Airflow & Fan Speeds with Noise Dampening Material) Boost Processor: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty A couple of questions:
1) Is there an advantage to the corsair TX power supply over the standard?
2) Is there any point to purchasing the corsair memory upgrade versus the Mushkin enhanced?
3) How much of a noise and temp difference is there between the noctua air cooling and the frostbite LC?
Thanks guys!
Quote Reply Posted: 01 Dec 2009 at 7:01pm |
1. corsair is a much better/reliable psu, you want the corsair or pc and power cooling but most people don't need more then 1000w.
2. not really 3. LC always gives better temps and is more quiet, however as far as noise goes, 90% of your noise comes from fan's of the gpu, so if you LC the gpu, then there is a huge difference in noise. your build looks great, if you ever see yourself going tri sli, then pic the 1000w corsair, looking at what you are doing, if I were you, to be on the safe side I would go with the 1000w corsair. |
