Control Panel Error?
Post Date: 2014-09-04
AtlaST View Drop Down
  Quote AtlaST Quote  Post ReplyReply bullet Topic: Control Panel Error?
    Posted: 04 Sep 2014 at 9:57pm
Hey guys,
Starting a few days ago, I get the following error message when I try to run the Control Panel application (that tracks/controls fan speed, case lighting, etc.):
I've checked the Device Manager like the error says, and have tried entering COM3, with no luck -- I get a popup that says "Error while connecting, make sure you use all CAPS, example: COM3"
Any ideas on where to go from here? Thanks for the help in advance.
Aventum II (Blue Storm)
i7 Extreme Edition 4960X OC'd to 4.8GHz
32GB DDR3 1866MHz Corsair Vengeance Pro
3x NVIDIA GeForce GTX TITAN Black 6GB
Digital Storm Copper Pipe Custom Cooling System
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Sep 2014 at 2:59am
Being a propriety design I can't say for sure, but it sounds like the control board for the lights and fans is defective. It does use USB as interface.   You could try unplugging other devices first or not plugging in a USB while the rig is on.
If you leave it on all the time, power off and reboot to reset devices.
Hope this helps but if not call DS. Let us know and good luck.
