controlling predator 360 pump and fansPost Date: 2016-05-19 |
funeralpyre88
Groupie Joined: 04 Feb 2011 Online Status: Offline Posts: 170 |
Topic: controlling predator 360 pump and fans Posted: 19 May 2016 at 9:06pm |
Ok, I have finished installing my new ASUS z170 pro gaming mobo, (the other one went defective) and I have my brand new ek-xlc predator 360 liquid cooling system, with both gpu and cpu waterblocks.
Now I want to know how to control the fan and pump speeds of the predator 360 so i can get optimal cooling. And since I have a new mobo, all my cpu and ram speeds are set back to default, how do I set them back to the high numbers they were before? I tried the "XMP profile" in the bios but it wasn't stable and crashed on desktop when I was running Heaven benchmark. |
core i7-6700k @4.7 GHz
Predator 360 cpu&gpu 16 GB DDR4@2800 MHz ASUS Z-170 PRO GAMING 256 GB SAMSUNG 850 PRO 500 GB SAMSUNG 850 EVO GTX 980 TI ASUS STRIX ACER XB270HU 2560x1440 @144 hz |
db188
Quote Reply Posted: 19 May 2016 at 11:59pm |
time to crack open that mobo manual and get into the bios and setup up your fan profiles. did the predator come with a manual to help out as well? do you have a DS fan control board installed in your rig? if not, do you have everything plugged into the mobo correctly? are you monitoring temps with software or via the bios?
i responded in your other thread about oc'ing quick tips. don't use the auto tune feature as it pumps in too much voltage. i want to make sure everything is hooked up and monitored properly at stock settings before you jump into oc'ing. Edited by db188 - 20 May 2016 at 12:02am |
Aventum 3
funeralpyre88
Quote Reply Posted: 20 May 2016 at 7:43am |
I don't have any software, I can only see the fan speeds with the bios, (the corsair link software is now useless, I don't have a corsair cooler anymore). I don't have a DS fan control board.
When I go into Qfan control, I'm pretty sure the "cpu fan" is the 3 fan radiator. I don't know what the CHA1 fan, CHA2 fan, and CHA3 fan are. |
