Coolant Fluid
Post Date: 2016-08-07
Litespeed911 View Drop Down
  Quote Litespeed911 Quote  Post ReplyReply bullet Topic: Coolant Fluid
    Posted: 07 Aug 2016 at 8:54pm
I have Apollo with HydroLux PRO: Exotic Custom Cooling System (CPU Only) purchased in may 2016. I need to top off my coolant reservoir, which EK fluid to use?? EK EKoolant Premium Liquid Cooling Premix 1L or the new EK-Ekoolant EVO UV BLUE premix 1L??
Thanks.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 9:16pm
DS uses different fluids, so you need to contact them and see what exactly they used in your system.
  Quote Litespeed911 Quote  Post ReplyReply bullet Posted: 07 Aug 2016 at 9:21pm
Yeah Alex from DS sent me a link to forzencpu that carry EK EKoolant Premium Liquid Cooling Premix Coolant - 1L - UV Blue but on EK website they carry the new EK-Ekoolant EVO is a brand new ready-to-use coolant, evolved from original EK-Ekoolant, designed specifically for computer liquid cooling systems with 3-year shelf life from date of bottling. So i was wondering which one to use??
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 12:19am
You use the one that Alex linked you to, if you want to use the other one, you need to flush your system and then go with the new fluid.
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 08 Aug 2016 at 2:00am
make sure you use distilled water to flush your loop.  don't use tap water, too many salts and things in it.   also, disconnect your psu (or use a separate one) from everything except the pump while flushing and filling your loop.  don't allow the pump to run dry, so you'll need to cycle the power on and off-the fluid will drain very fast from the reservoir at first, so be careful.
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
