CPU FAN ERROR?Post Date: 2016-03-20 |
21QZ
Newbie Joined: 28 May 2015 Online Status: Offline Posts: 33 |
Topic: CPU FAN ERROR? Posted: 20 Mar 2016 at 10:37pm |
Hello, I have a Bolt 3 with liquid cooled CPU and GPU. I accidentally pressed a button on my mobo and now I get this error on start up. Help?
Quote Reply Posted: 21 Mar 2016 at 2:33am |
Sounds like you hit the clear cmos button. If you also lost the CPU overclock then that's it. You'll need to go into Bios and load a saved Overclock Profile. For Asus boards it's under the Tools tab. For Asrock, etc I'm not sure. Use the manual.
With water cooling , the CPU fan header on the motherboard might not be used so it needs to be put to Ignore in Bios. Good luck. |
21QZ
Quote Reply Posted: 21 Mar 2016 at 11:20am |
Yeah I hit that button by mistake and regret it. Hopefully a tech can step me through how to fix it, if no one here can.
Quote Reply Posted: 21 Mar 2016 at 11:27am |
Depends what motherboard you have. You'd need to go into Bios, DEL key while booting, go to the Advanced screen then Tool tab and highlight and load the saved profile That's for Asus. For Asrock, I think the Saved profiles are under the OC Tweaker tab. I'm guessing the top profile, but not sure.
Call or Email DS if you need to. |
