Custom Loop from you, maintenance question
Post Date: 2018-06-14
Hechtic View Drop Down
Avatar
  Quote Hechtic Quote  Post ReplyReply bullet Topic: Custom Loop from you, maintenance question
    Posted: 14 Jun 2018 at 4:21pm
So I got a custom loop from you guys, and I am now getting close to 9 mos of ownership, and have started to wonder if and when I should be draining and refilling the loop. This is my first non-AIO unit so I could use an idea of when I should do this type of maintenance.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 15 Jun 2018 at 2:00am
If it’s running fine and the fluid is not discolored then I’d leave it alone.
That said, some believe in a yearly flush and new fluid to prevent issues and others , including DS, believe it’s good for years.
I don’t have a custom loop, but if I did, I would “fix it” only if needed.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 15 Jun 2018 at 2:12am
I had to change mine for replacing some fittings after about 2 years and it was pristine (clean and clear). So, unless you have some temp. issues or other coolant related problems, I'd go with bprat22 suggestion and leave alone and enjoy. Big%20Smile
  Quote hoserator Quote  Post ReplyReply bullet Posted: 15 Jun 2018 at 3:44am
Just curious, what is it mounted on and what is it cooling? Is it pigmented? Smile
SnowandSand View Drop Down
Avatar
  Quote SnowandSand Quote  Post ReplyReply bullet Posted: 15 Jun 2018 at 4:40pm
I ended up redoing the tubing in my loop, adding a drain port, and flushing it after 18 months, due to some algea I saw in my res. I had a post on here around last September about it.
Hailstorm II
I7-6700K/4.5GHz
16GB DDR4 2666MHz
Asus Z170 Maximus VIII Hero
Corsair Hx1000i 1000W PSU
250GB Samsung 850 EVO
1TB & 6TB WD - Black Edition
2x GTX 980TI 6GB Asus Strix
Hydrolux Stage 3
This page was generated in 5.664063E-02 seconds.
