DS Cooling Sneak Peek
Post Date: 2010-10-13
venom View Drop Down
Avatar
  Quote venom Quote  Post ReplyReply bullet Topic: DS Cooling Sneak Peek
    Posted: 13 Oct 2010 at 2:03am
Couple of pics of the new cooling system...  More to come soon!
The two pics above are while CPU is idle if anyone is wondering.
Edited by venom - 13 Oct 2010 at 1:54pm
rholyrag View Drop Down
Avatar
  Quote rholyrag Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 6:45am
Awesome...Awesome!  Thanks for the pics!
MagiK View Drop Down
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 7:35am
It looks like you have frost on the CPU cooler and the MoBo around it  Whoa
Avatar
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 9:32am
That is going to be the trick.
Venom, are you guys using ambient temp probe(s) to control the water temp? or preset temp? With ambient temps having a 20 degree swing, and humidity going from 20%-90%. seems like if it was preset, for worst condidtions, the temps would not be that great?  95F room with 90% RH would require the fluid temp to be 92F-93F, yet in my office, this morning, you could have the fluid 55F and have no problems.. manual control would be fine for some users, but not for others. ??
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 9:52am
Ugh Id hate to have to be in a 95 degree room.  If man were meant to be in that hot a temperature he would never have invented AC  Whoa
On a more serious note, I wonder what our indoor relative humidity is....going to have to find some way to tell.
Avatar
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 10:25am
indoor RH varys greatly. I have measured many, many homes, part of my job, 20%-95%, plus it will vary with weather, and seasons..
95F with AC on in my office sometimes.. to much heat created from all the damn electronics, 70F in the rest of the home.. LOL
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 10:33am
Im thinking ours should be somewhere between 40 and 60% in our house with the house temps in the low 70s and in the upper 70's in my office (We have a humidifier on our Heat/AC system)   I do appreciate the heat generated by my equipment in the winter time, keeps me nice and toasty while the wife is wandering around the rest of the house in heavy sweaters.
Edited by MagiK - 13 Oct 2010 at 10:34am
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 11:43am
In the final build, the water block and such will have foam to insulate it.
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 11:53am
Foam...mmmmm  Foam is good...sent you a request to be put on the waiting list Alex along with a second email with a rough Idea of what I wanted in the Build.
Avatar
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 12:07pm
what about the base of the water block?
Avatar
  Quote venom Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 12:38pm
The scythe controller is just monitoring the temp of the quick disconnect, didn't have a water temp probe to connect (yet).  Currently there isn't an ambient probe controlling temps.
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Oct 2010 at 5:37pm
<FONT style=": #000000">what about the base of the water block?
Yes. It will.
Edited by Alex - 13 Oct 2010 at 5:38pm
Avatar
  Quote venom Quote  Post ReplyReply bullet Posted: 23 Oct 2010 at 7:11pm
CPU Idling @ 4.6GHz. Ninja
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 1:19pm
ugh water water everywhere, system short waiting to happen  Whoa
AmbientChong11 View Drop Down
Avatar
  Quote AmbientChong11 Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 3:07pm
There should be some kind of filter if possible around the waterblock.
Avatar
  Quote MagiK Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 4:13pm
Alex said they were going to encase the water block in some kind of foam to prevent condensation...I think.
Avatar
  Quote venom Quote  Post ReplyReply bullet Posted: 24 Oct 2010 at 8:50pm
Yeah the final version will be insulated, I just thought it looked kool with ice on the block while running.  I think that was -6c in that pic.
