Dual Solid State Hard Drive Hot Swap BayPost Date: 2016-02-09 |
eric1
Newbie Joined: 12 Jan 2008 Online Status: Offline Posts: 12 |
Topic: Dual Solid State Hard Drive Hot Swap Bay Posted: 09 Feb 2016 at 9:36am |
Does anybody know If I get an Apollo with Dual Solid State Hard Drive Hot Swap Bay will it be prewired so I can just drop an ssd in and be ready to run? Thanks.
Quote Reply Posted: 09 Feb 2016 at 11:33am |
Hi eric1... Go to the configurator for Apollo and under the Expansion bay section you'll see the hot swap bay options. They have them for HDD and SSD.
Good luck. |
giants84
Newbie Joined: 15 May 2015 Online Status: Offline Posts: 90 |
Quote Reply Posted: 09 Feb 2016 at 12:34pm |
Are those worth getting?
db188
Quote Reply Posted: 09 Feb 2016 at 1:35pm |
it's convenient but not as securely mounted. unless you're actually using it as intended (swapping drives in and out of the computer on a frequent basis) it's probably safest to secure "permanent" drives the traditional way.
Aventum 3
