emote Controlled LED Lighting System QuestionPost Date: 2015-10-16 |
fruhlinginparis
Newbie Joined: 29 Aug 2015 Online Status: Offline Posts: 10 |
Topic: emote Controlled LED Lighting System Question Posted: 16 Oct 2015 at 10:05am |
Ok, so i ordered emote Controlled LED Lighting System (Multiple color options and lighting effects) on my new PC it came with the remote and everything but when i press a button on the remote to change the color is does not do anything. The remote is working and everything because the remote clearly lights up when i press a button, but nothing happens to the PC. am i missing something? Do i need to install a program for this to work?
db188
Quote Reply Posted: 16 Oct 2015 at 8:08pm |
if it's an IR remote make sure you're pointing it at the sensor inside your rig. even though you're seeing the power indicator light up you could still have a faulty remote or even a faulty sensor, faulty wiring, etc. make sure all connections are secure. try unplugging/plugging from power supply/control unit. if all else fails contact DS support.
are you stuck on one color or no lights at all? Edited by db188 - 16 Oct 2015 at 8:10pm |
Aventum 3
