Fans with zero noisePost Date: 2016-02-26 |
jackbnimble
Newbie Joined: 07 Feb 2016 Online Status: Offline Posts: 11 |
Topic: Fans with zero noise Posted: 26 Feb 2016 at 4:52pm |
Just wondering, Is it safe to have the fans all the way down with zero noise? I would not want to damage my system. Thanks Also is there any safety feature that would keep the components from every getting to hot when fans are turned down? moved question to new thread Edited by Snaike - 26 Feb 2016 at 10:45pm |
Snaike
Quote Reply Posted: 26 Feb 2016 at 10:47pm |
Yes, they're called HWMONITOR, SPECCY, REALTEMP, etc
These are temperature monitoring programs that allow to you see how hot your machine is running. If you've turned your fans all the way down, or off, you need to be acutely aware of how hot your machine is getting. Remember, when it comes to electronics in general and computers specifically: Heat Kills. |
db188
Quote Reply Posted: 27 Feb 2016 at 12:20am |
pretty much these days the cpu and graphics will throttle themselves down when they get too hot. however, a spike due to adding too much voltage during oc'ing or an electrical surge can cause damage. also, a bad mobo that doesn't regulate the power delivery appropriately can hurt your other components. bottom line is that you can and will damage your components if you don't monitor your temps, clean your pc, and provide adequate cooling.
as long as you have adequate cooling, and the more you have the more you can afford to run your fans at lower rpm = less noise. i've got 13x140mm fans and 2x120mm total in my rig, with 3 rads and a pump. if i don't need the performance while the system is under heavy load (like while bench marking/testing) i run my fans at the lowest speed, which is probably at the 5-volt setting. it's extremely quiet and cool because i have so many fans and rads cooling my components in a custom water loop. even under extreme performance i don't need to run my fans at anywhere near 100% or 12-volts. i would say it's very common for most users running moderately taxing games under load to need to run their fans on the 7 or 12-volts settings. that can be fairly noisy depending on how sensitive you are to it. make sure you have static pressure fans (fewer but wider blades) mounted to radiators and in places inside the computer where air has to penetrate through clutter/obstacles. air series fans (more but thinner blades) are fine for exhaust and areas of the interior where there are no obstructions (i.e. side fans). consider using static pressure fans as intake fans if you have hard drive cages/drives/etc. to blow air through. consider using larger fans with lower rpm over smaller/higher rpm fans. some ppl like to leave their comps on 24/7, i don't leave mine on for a couple of reasons: 1) i like to monitor temps/performance at all times for safety; 2) save on my electricity bill; 3) security Edited by db188 - 27 Feb 2016 at 12:36am |
Aventum 3
