fatest RAMS for my motherboard?( Latency and MHZ )Post Date: 2016-01-04 |
saitama
Newbie Joined: 04 Jan 2016 Online Status: Offline Posts: 2 |
Topic: fatest RAMS for my motherboard?( Latency and MHZ ) Posted: 04 Jan 2016 at 7:08pm |
Hi all!
I'm going to buy RAMs for my ASUS ROG MAXIMUS VIII EXTREME LGA1151 and it has only four slots, I have never looked into latency before and a friend of mine told me it matters a lot but I realized the more Mhz the higher the Latency goes .. and iam confused because i read everywhere that the lower the latency the better soo -.-? can someone tell me should I go for higher mhz or I find the lowest latency? and I only have 4 slots on the motherboard which is a downside but after researching it appears its the best LGA 1151 motherboard and it goes well with the 6700K processor correct me if I'm wrong. I just need the best build. so far options : G skill ripjaw, corsair dominator plantinum I'm not sure why g skill is so cheap compared to corsair dominator plantinum and there are so many G skill options not sure which one is the best.. I just need the best x4 Rams for my motherboard money is not an issue so don't consider it as a factor please I will run the rams at its stock speed THANKS ALOT |
Quote Reply Posted: 05 Jan 2016 at 11:18am |
Here's an article that describes latency vs speed.
http://www.crucial.com/usa/en/memory-performance-speed-latency Kinda confirms my understanding that speed is more important than the latency. |
