First build for Day Trading - Advice?
Post Date: 2016-08-14
Page  123>
mikeb029 View Drop Down
  Quote mikeb029 Quote  Post ReplyReply bullet Topic: First build for Day Trading - Advice?
    Posted: 14 Aug 2016 at 2:32pm
$1,850 +/-
First build and fist order from DS. I've done a lot of research and settled on DS, but I'm not a techy and getting a little overwhelmed with the options. Kindly seeking advice and build recommendation from the knowledge base here.
This build will not ever be used for gaming, but rather mainly for Day Trading as it's my profession. So, mainly my trading platforms and software, web browsing, and Office (home and student). Usage will be all day every day and partial use on weekends. Driving 4 Lenovo Thinkvision IPS LED 23.8" monitors (7ms response time, 1920x1080) and will never have a need for 4k.
My main concerns are speed, longevity and noise level. Standard hum along type sound is just fine, but I'm a little squeamish because I had to return a computer a few months ago that got a little ridiculous when the fan kicked in.
No games, videos or movies will ever be downloaded.
I do think I want a 4.0ghz CPU and 16GB. Can anyone recommend a build?
Thanks so much in advance!
[Please Type Here]
[Please Type Here]
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Aug 2016 at 4:27pm
Some info:
1. 90% of the noise of a system on air comes from the gpu's fan when under heavy load.
2. to get quiet pc you need to put everything on liquid cooling, this will go over your budget but still with lc you are still dealing with fans, so if you truly want a pc is quiet, you need to go custom lc and custom fans, and that really goes over the budget.
3. now for your use I don't see gpu fan noise being an issue but you sound like you are very sound conscious and I'm not sure how an air system will sound to you, to me it would be ok but to you it maybe loud.
Now I can simply tell you to get this and that and you will be fine but I'm not the type to guess things like that so please let me know what you think about this info.
we can use noise suspension and lower fan speeds but in return your temps could go high at your house and then you would need to set the fan higher and thus more noise, which is why I think its best to go with a quiet fan/setup right off the bat.
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 14 Aug 2016 at 5:21pm
Originally posted by DST4ME
Some info:
Ok, let's go with the quietest set up possible within my budget (maybe push it to $2,000) without sacrificing gpu speed. If DS rigs are not any louder than industry standard then it is what it is and I will simply have to deal with how they sound. :)
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Aug 2016 at 6:45pm
To be honest as I'm trying different configs, the hydrolux pro (the lc system) is pushing us to over $2500 and that is with a 1060 and an i5 6600k, which I rather have you in 6700k which then pushes us to around $2700. And we have not even got to asking DS to install quiet fans on the pc / lc system.
I would put you in a lower lc system but I'm not confident about the noise level.
How would you like to proceed?
for example I could tell you to get a bolt like this config but I'm not comfortable with doing that, both for temps and noise:
Ticket Number: 1470925
the other build I would feel comfortable recommending as a base,(as in a start point to which we still have to make modifications to) is this one but as I mentioned the price is above your budget:
Ticket Number: 1470929
Edited by DST4ME - 14 Aug 2016 at 6:48pm
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 5:30am
Now I don't know if I'm being too conscientious about fan noise or if these machines are just loud. For example, in your opinion, is a non-lc DS machine louder than, say an Ibuypower with same specs? If not, than i'd probably be OK with it. Does DS publish Db ratings?
$2,500 is over budget...we'd need to keep it down around $1,800-$2,000. thank you......
Mike B.
soulmanim3 View Drop Down
  Quote soulmanim3 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 6:23am
Thoughts on this one:
1254398
With no games or streaming I doubt you'll hear it too much according to the reviews. I haven't received mine yet, so I can only speculate
May have more storage than you need too. If so, removing the mechanical drive would reduce a bit of noise. Added premium fans too.
Ordered - 07/02/2016 | Stage 7 - 08/15/2016
Stage 1 - 07/05/2016 | Shipped - 08/16/2016
Stage 2 - 07/11/2016
Stage 3 - 07/11/2016
Stage 4 - 07/26/2016
Stage 5 - 07/26/2016
Stage 6 - 08/04/2016
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 9:01am
I like your build, but added 8GB. I have 3 builds here with same GPU speed, Graphics card and stock cooling.
1471299 (vanquish level 4) $1,482
1471302 (Apollo level 2)    $1,802
1471304 (Slade level 2)     $1,704
The Apollo and Slade have name brand (samsung) SSD
The Apollo has 240mm lc (both vanquish and slade have 120mm)
Do I need name brand SSD and 240mm lc?
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 12:48pm
IMHO with 4 monitors you are going to have noise no air, I trade also with multi monitors btw myself.
if its the same fan for example you will not notice a difference no matter where you go.
so no DS system is no louder then any other systems with the same specs.
if you want to be on air then go with this for most power and least amount of noise on air:
Ticket Number: 1471462
You want brand almost all the time unless budget does not allow so that you know what you are getting, ram can be different a bit, for ssd I would only go samsung here.
Edited by DST4ME - 15 Aug 2016 at 12:49pm
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 2:23pm
DST4ME..it doesn't matter to me if I'm liquid cooled or fan. I'm just looking for the best/quietest cooling option that fits my $2,000 budget. And you're saying your config 1471462 fits that bill? Thanks so much...
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 2:41pm
No what I was saying is that if you are going to go with the builds you suggested then my build would be more quiet then the builds you suggested. Otherwise what I said before stands about most quiet system = cpu/gpu on lc = price higher than $2000.
you see the only way for us to make your gpu quiet is to put it on lc, a basic lc system will have loud fans if the system is going to get warm or hot. Now do I know if your pc is going to get hot or warm? I don't know, and instead of gambling with whether it will or not, I choose to take the stand that lets assume it will, in that senario what kind of cooling would do better? that would be lc, now if I want quiet lc then I have to put quiet fans on the lc system, for this we need to go hydrolux pro, HDpro will put us over the budget of $2000.
Hope that helps, Now theoretically if your cpu and gpu don't get warm enough, specially the gpu, so that it's fan does not have to spin higher, then you would be ok, but with 4 monitors I assume your temps will go up when you are running the interactive stuff.
build 1471462 will be quiet as long as there is not much load on cpu or gpu otherwise gpu on air + good load = high fan = loud noise.
Hope that clarifies, I'm not the type of person who is gonna put you on air and tell you that you gonna be fine when I don't know if you will for sure and it seems the noise is important to you, so I want to give it that much attention.
assuming the fans on the hydrolux lite are quiet then this build is what I would go with, again assuming fan on the rad for the lite version are quiet under load.
Ticket Number: 1471543
problem is they may seem quiet to us/me but not to you.
Edited by DST4ME - 15 Aug 2016 at 2:45pm
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 2:52pm
Understood..thanks! One LAST question if I may: Your previous Apollo build (1471462) with the Air ONLY option...wouldn't the Slade version of that be more quiet?
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 3:25pm
Slate has more fans which I'm not sure how loud they would be to you, I would assume the case fans will be quiet and should not bother you, that being the case then perhaps the slate would be more quiet but that will raise the price plus we are on air, which again I'm not comfortable saying that on air a system is going to be quiet.
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:18pm
@25% PWM (fan speed 800rpm Swiftech)(420 rpm Noctua)  =  36dba (Swiftech), 34dba (Noctua D15)
@50% PWM (fan speed 1250rpm)(830rpm) = 38dba (Swiftech), 36dba (Noctua D15)
@100% PWM (fan speed 2030rpm)(1525rpm)  = 46dba (Swiftech), 43dba (Noctua D15)
temps performance results
stock cpu (I7-6700K) at idle = 24C (Swiftech), 25C (Noctua D15)
oc (4.6GHz) = 24C (Swiftech), 25C (Noctua D15)
typical load @stock speed w/Prime95 = 53C (Swiftech), 56C (Noctua D15)
"               " @oc w/Prime95 = 66C (Swiftech), 69C (Noctua D15)
general usage temps differences were within 2 degrees C of each other.
hopefully this gives you a better idea of the relative performance between the top air cooling (Noctua D15) that DS offers and its hybrid AIO DS Pro Lite (rebranded Swiftech H220x2) liquid cooling options.
Edited by db188 - 15 Aug 2016 at 4:19pm
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:21pm
db did you grab those from swiftech's site or a personal bench? I find they bs the numbers a bit.
at 43db I think he will come to my house and take my head off I think at 36db he is still not gonna be happy.
Thanks for the info db
Edited by DST4ME - 15 Aug 2016 at 4:22pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:30pm
those numbers are from a TechPowerUp review based on the Swiftech H220X2 Prestige model vs a field of other air and LCs.
on a side note the Corsair 400Q case (from an Anandtech review) states it has 170mm clearance for air coolers.  the Nocuta D15 is 165mm w/fans attached/160mm w/o fans attached.  might be a tight fit for the air cooler in this case (DS Slade).  DS can confirm whether it fits right or not.  even if it does fit it could lead to more chance of shipping damage due to any flexing of the side panel, just fyi.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:32pm
also, i don't see much need for his usage to run the fans at 100%.  day trading programs aren't particularly demanding even with working on 3+monitors.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:32pm
Normally now the config will let me know if its an issue, so I thought it would fit, but either way I don't think he is gonna be happy with high 30s in the dba.
Lets see. Do you know if DS changes the fans on swiftech?
3 monitors+ and interactive trading software, it will get the gpu warm enough for the fan to kick in, at least it does for me.
Edited by DST4ME - 15 Aug 2016 at 4:35pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:36pm
i doubt it.  but i think Swiftech uses those NoiseBlocker e-loop fans, which are pretty good.  if he wants quieter fans he'd have to look at some Apache Black or GentleTyphoons i would think.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:39pm
he'll probably hear the gpu cooler over the cpu cooler in that case.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:40pm
I was thinking SGT also, I think he wants to be below 30dba to be quiet, he is adamant about it being quiet.
agreed on gpu, which is why I'm telling him to put gpu on lc.
he said he has already returned a pc to a different builder due to noise.
Edited by DST4ME - 15 Aug 2016 at 4:41pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:42pm
well, the 400Q does come with noise dampening foam inserts on its panels, and the previous Slade was a 550D case.  i watched a vid testing out that 550D with max fans running 100% and it was pretty "silent".  i don't know if the new "silent" 400Q is as good or not, but it should be quiet enough.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:44pm
well, he's restrained by budget and there's only so many options for his price range
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:49pm
I agree with both our posts.
The vid you saw were the fans case/cpu fans or gpu fans or all? I assume it was not gpu fan at 100%
I badly want to say that with swiftech he is gonna be fine with both cpu/gpu but I'm just afraid if it gets to 50% load on the fan he is gonna be mad.
Edited by DST4ME - 15 Aug 2016 at 4:50pm
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:51pm
it was whole system build, so yeah it included the gpu being ran under extreme load with fans maxed.  i can't remember the gpu model, but it was probably a reference card for testing purposes.  it was pretty amazing, i couldn't believe how good that 550D was from an acoustics perspective.  the thermal performance was midling, but that's what you get with a "closed case".
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:53pm
it would be nice if DS had better fan choices for upgrades so they could really build a "silent" pc, those Corsairs just don't cut it for either performance or silence-at least compared to some of the better options out there.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 4:55pm
well, it would probably consume his entire pc budget just to get him a silent custom open LC loop to do it really right.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 5:01pm
Preach brother preach
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 5:02pm
@25% PWM (fan speed 800rpm Swiftech)(420 rpm Noctua)  =  36dba (Swiftech), 34dba (Noctua D15)@50% PWM (fan speed 1250rpm)(830rpm) = 38dba (Swiftech), 36dba (Noctua D15)@100% PWM (fan speed 2030rpm)(1525rpm)  = 46dba (Swiftech), 43dba (Noctua D15)temps performance resultsstock cpu (I7-6700K) at idle = 24C (Swiftech), 25C (Noctua D15)oc (4.6GHz) = 24C (Swiftech), 25C (Noctua D15)typical load @stock speed w/Prime95 = 53C (Swiftech), 56C (Noctua D15)"               " @oc w/Prime95 = 66C (Swiftech), 69C (Noctua D15)general usage temps differences were within 2 degrees C of each other.hopefully this gives you a better idea of the relative performance between the top air cooling (Noctua D15) that DS offers and its hybrid AIO DS Pro Lite (rebranded Swiftech H220x2) liquid cooling options.
Pretty close..thanks DB
Mike B.
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 5:08pm
my pleasure, gl with your buildBig%20Smile
Aventum 3
I7-6700K
Gigabyte M28U 4K
Richieboy67 View Drop Down
  Quote Richieboy67 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 5:12pm
Day trading?You will use multiple monitors and running many tasks at the same time?
Lots of ram and a cpu with many cores would be what I would base that build from.
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 6:27pm
Originally posted by Richieboy67
Day trading?You will use multiple monitors and running many tasks at the same time?Lots of ram and a cpu with many cores would be what I would base that build from.
Thanks...I was planning on the i7 6700k and 16gb
Mike B.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 6:30pm
So tell us what you think and what you are thinking now as far as noise and air and lc?
  Quote mikeb029 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 7:12pm
I actually don't know. I've read enough to know the Dba's listed above are loud. As one website put it; "too loud to concentrate or study." Not relevant to gamers..I get that.
Maybe the Slade casing dampens that somewhat? I would imagine? A little odd DS doesn't have a Db rating on at least stock Slade builds since it's built for quiet.
Sitting on my hands for now...
Thanks for all of your help though..will keep my eyes peeled.
Mike B.
  Quote db188 Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 7:30pm
from Anandtech's review of the Corsair 400Q (DS Slade):
Thermal testing has been performed with all of the case's stock fan operating at maximum speed. Noise testing has been performed with a background noise level of 30.4dB(A). Advanced noise testing is also being performed, in order to assess the ability of the case to dampen the noise of the components installed inside it. This includes the installation of two noise-generating sources (strong fans) inside the case, one positioned approximately over the first expansion slot and one over the CPU area, which generate ≈ 44.2 dB(A) when unobstructed. During the advanced noise test, all stock cooling options of the case are entirely disabled.
(talking about the Corsair AF fans included) Combined with the sound dampening material, they made the Carbide 400Q one of the lowest noise ATX tower cases that we have ever tested. The Carbide 400Q showed very good sound dampening capabilities as well, reducing the sound pressure generated by our dummy noise source by 5 dB(A), from 44.2 dB(A) to 39.2 dB(A). The dB(A) scale is logarithmic and that translates to a sound pressure reduction of over 60%, which is easily discernible by the human ear.
they tested this case with an 820watts thermal load.
Aventum 3
I7-6700K
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 15 Aug 2016 at 10:57pm
How about hydrolux lite but we change the fans with Scythe gentle typhoon fans then, that should quiet it down with those.
I have not worked the swiftech tho and I'm not sure if you can change fans on it.
Also what dba are you aiming to be around, keep in mind 20s would be a great success.
Based on the review db provided for us for the case lets assume it does take 5 dba away from total system noise.
Edited by DST4ME - 15 Aug 2016 at 10:59pm
