First Time Trying To Overclock Help
Post Date: 2012-07-30
rsmilford View Drop Down
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Topic: First Time Trying To Overclock Help
    Posted: 30 Jul 2012 at 3:51pm
I have an old enough system here and felt it's time to learn how to overclock, Im going to need some advice and guidance so let me start by saying thank you all for helping.
The System:
Power Supply: 550W Corsair HX
Processor: Intel Core 2 Quad Q6600 2.4GHz(1066MHz) (8MB Cache)
Processor Cooler: Freezer Pro 7
Motherboard: nVidia 750i SLI FTW (123-YW-E175-A1)
Memory: Patriot PC2-8500 1066MHz 2x2GB(4GB) (5-5-5-15) (2T) (2.1V)
Hard Drive: 160GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 450GTS (EVGA)
Anyhow I have done some reading up on other builds like mine that were overclocked and tinkered around bios to become familiarized with the settings and I noticed that I cannot select the CPU frequency at all, although I can change all the voltages and memory timings.
Can anyone give me directions or advice on what i need to do in order to Overclock my CPU with preferably stock Voltages 1.325v CPU Core (I don't want to generate more heat than this case can handle)
I would be happy with 2.7GHz+
Edited by rsmilford - 30 Jul 2012 at 4:01pm
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:01pm
There's some good threads about your specific CPU on the EVGA forums if you haven't checked them out yet. I'm unfortunately not too familiar with your platform, which BIOS revision are you using?
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:06pm
Im Not sure what that means but I had flashed the Bios Recently with
Driver Version: SZ1K
Release Date: 12/1/2009
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:07pm
How do i check my BIOS revision
(edit) I think i got it.
Edited by rsmilford - 30 Jul 2012 at 4:11pm
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:10pm
BIOS Version/Date Phoenix Technologies, LTD 6.00 PG, 11/24/2009
SMBIOS Version     2.5
Hope this helps
Edited by rsmilford - 30 Jul 2012 at 4:10pm
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:15pm
You don't adjust the frequency itself, you change it via other options explained in the guide below. Sorry I can't help more, I didn't really start overclocking until the i7's came along so I can't offer too much specific insight into the C2Q and its finer tweaking.
And yep, that's what I needed. I was trying to find a guide that would encompass your mobo type and BIOS version.
Check this one out, its pretty thorough Awesome:
http://www.overclockers.com/forums/showthread.php?t=515316
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:17pm
Thank you sir
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:23pm
No problem, you'll have that 2.7Ghz in no time (probably more if you like!)
Good Luck! Strong
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 4:59pm
Ok, So i got it set to 3.0Ghz
FSB 1333 9x Multiplier
any sources for what voltage i should use the auto setting wants me to go to 1.45V that seems too high for 3.0GHz
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 5:02pm
For the voltage AUTO is almost always too high, I'd try decreasing it down to 1.39v and testing for stability.
Edited by Tidgxor - 30 Jul 2012 at 5:02pm
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 5:55pm
Ok, what about the CPU fsb voltage the one under core voltage i set it at 1.3 it was at 1.45(auto)
also what is a good program to test?
tju76 View Drop Down
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 6:28pm
For a quick check of stability use intel burn test and run 10 passes at maximum, then try prime 95 and run for atleast 12 hours I run it for 24 hours. Make sure you use a temp monitoring program use real temp and also download cpu z these programs are all free and easy to use. Post some screenshots of your temps and everything
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 8:36pm
Well this was fun i learned alot on how to overclock a system sadly this one i tried to overclock cannot run stably temps most likely due to the case's air flow.(digital storm 750si which is a SilverStone case)
The case only has two 120mm fans, one in the back and one in the front and this front one doesn't even have vents to pull air. Anyway I set the CPU back to 1066 FSB (2.4GHz)and set the voltage to 1.2 (auto 1.325)which dropped the temps quick significantly and its running stable on the Intel Burn Test.
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 9:03pm
What do you have for a cpu cooler? If your want to get into oc I suggest maybe just picking up a sandybridge and an h100
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 30 Jul 2012 at 9:05pm
if you failed your first attempt just lower the oc a little and try again. Overclocking is a process of trial and error. What were the cpu temps at? What are they at stock config
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 01 Aug 2012 at 8:30pm
The cooler is a Arctic Cooling Freezer 7 Pro and the case is an old Silver Stone with negative airflow and almost no vents to pull air from its a crappy case and and old build at that so im not to worried to get this overclocked. I did think about buying a new case but I need to save for a new computer all together.
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 01 Aug 2012 at 8:41pm
The case is like a Silverstone TJ04 but only has 1 fan in the back and 1 in the front and this front fan doesn't have a vent to pull air from. I think im going to look into adding some fans or vents if i can.
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 11 Aug 2012 at 9:12am
So I put a 200mm fan on the side of my case which I believe is the TJ02.
Temps are better on the gpu but the cpu is still kinda hot for overclocking so I ordered some:
1 x ($9.95) CPU THERMPASTE|AS5-3.5G
1 x ($6.99) CPU CLEAN|ARCTIC CLEAN ACN-60ML
After I clean the processor and reapply some thermal paste I will try to overclock again, I'm told this will help lower the temps.
Also the computer was purchased at DS in 2008 so I'm guessing this needed to be done anyway, Does anyone know how long thermal paste lasts?
Edited by rsmilford - 11 Aug 2012 at 9:16am
Avatar
  Quote tju76 Quote  Post ReplyReply bullet Posted: 11 Aug 2012 at 9:32am
Hmm that's a hard question
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Aug 2012 at 12:09pm
There are a lot of variables in place when it comes to how long a thermal paste will last.
High quality pastes, under normal usage, will easily maintain high performance for 3-4 years.
Budget and generic pastes will probably start to decline after about 16 months of normal usage.
Intensive usage, might burn the paste up every 4 months or so. And by intensive I mean high OC with high voltage, and constant CPU usage. (Most likely not you, as gaming is not "intensive usage" in regards to a CPU).
Edited by Tidgxor - 11 Aug 2012 at 12:10pm
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 11 Aug 2012 at 12:17pm
ok, so I am due for new thermal paste after all, I'm curious does DS use High Quality Thermal Paste on there builds.
(edit)I think these heatsinks come with factory thermal paste already on them already and arctic freezer supposedly makes some good paste
Edited by rsmilford - 12 Aug 2012 at 4:30pm
Avatar
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 11 Aug 2012 at 12:26pm
Well of course Alex will tell you that they do Big%20Smile
I'm not sure on which exact brand/type they use though.
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 12 Aug 2012 at 4:09pm
I have been trying to figure out how to properly remove the Arctic Freezer 7 Pro (1st Generation) it's on a LGA775 and uses push pins am i going to have to remove the motherboard to do this
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Aug 2012 at 9:30am
If it uses push pins, you should not have to. You'll need to turn the knobs counter clockwise to unlock them, then pull each one and they should come out.
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 4:09pm
Right on Alex. I found a good thread on this that explains what you just said with pictures.
http://www.overclockers.com/forums/showthread.php?t=551786
I just got some AS5 and cleaner now that hard part "sausage fingers" removing it.
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 5:05pm
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 8:56pm
Alright got her done and lucky for me i didn't break any pins. Temps came down a little bit not much, The old thermal paste was a mess and looked old and crusty i should have taken pictures i know but i was in a hurry. anyhow i cleaned it off with:
1 Arctic Clean Thermal Material Remover
2 Arctic Clean Surface Purifier
^^^^^ Stuff Works Great^^^^^
Than Applied Arctic Silver 5
I watched many videos on how to apply this stuff which is not that technical, I used a credit card and got a nice even spread with minimal thermal compound yet enough so I couldn't see any processor shining through.
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 9:02pm
The System:
Video Card: GTX 560Ti 448 Cores Classified (EVGA)
Got a new GPU ^^^^
Now on to the overclock, I tried 3GHz but could not get temps stable they were exceeding 65c degrees
So i settled with 2.7 stable not exceeding 63c
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 10:10pm
ehh should i have done the "pea" method when applying the thermal paste?
In other words should i have put one glob of paste in the middle instead of spreading it.
SpicierMire View Drop Down
Avatar
  Quote SpicierMire Quote  Post ReplyReply bullet Posted: 14 Aug 2012 at 10:49pm
Looking good! Now all you have to do is turn off Aero & Themes for an even better perf gain
Avatar
  Quote rsmilford Quote  Post ReplyReply bullet Posted: 15 Aug 2012 at 4:49pm
this is true i turn those off time to time its amazing how much power It sucks down that's why I'm glad to here Windows 8 will do without Aero. I just wish Windows 7 Standard had a black window boarders and task bar.
This page was generated in 0.1699219 seconds.
