Front FanPost Date: 2016-09-12 |
RevolvingStorm
Newbie Joined: 20 Jun 2016 Online Status: Offline Posts: 7 |
Topic: Front Fan Posted: 12 Sep 2016 at 9:44pm |
recieved my new vanquish 5 months ago and just noticed my front fan out of 3 isnt working everything seems to be plugged in but is their something else that could prevent it from working?
Quote Reply Posted: 12 Sep 2016 at 10:20pm |
check its connections.
hoserator
DS Veteran We don't need no stinking "Avatars" ! Joined: 08 Oct 2014 Online Status: Offline Posts: 7960 |
Quote Reply Posted: 13 Sep 2016 at 2:38am |
Hi RevolvingStorm,
Make sure that the blades spin freely and are not stuck. |
FrankW
Quote Reply Posted: 13 Sep 2016 at 4:22am |
Hi RevolvingStorm,
You are still under warranty so give DS a call. They will help you trouble shoot and ship you a new fan if necessary. If the power cable from the working fan on the front will reach the non-working fan on the front, switch the leads at the fan. If it is a wiring problem the bad fan should operate with the other fans cable. If the bad fan doesn't work with the good cable then the fan is bad. Frank |
