Gaming Pc helpPost Date: 2017-03-13 |
JadenLuck
Newbie Joined: 13 Mar 2017 Online Status: Offline Posts: 2 |
Topic: Gaming Pc help Posted: 13 Mar 2017 at 5:19pm |
Budget is around $2000 anywhere around that i will be fine with. Expectations: Expecting to play games like cs, h1z1, arma 3, etc with the graphics and fps i can get. Usage: Play games like i said uptop and also just every now and then surfing the web with minimal watching streams. Special Needs: No special needs Saved Ticket #: dont know what this is Specifications: Dont know what this is |
Nomad1970
Senior Member Joined: 23 Feb 2013 Online Status: Offline Posts: 716 |
Quote Reply Posted: 13 Mar 2017 at 5:57pm |
I would say a Vanquish 5 level 3 for $1765.00 would fit your needs well. But wait and see if someone else has a different idea.
Edited by Nomad1970 - 13 Mar 2017 at 5:57pm |
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
Snaike
Quote Reply Posted: 13 Mar 2017 at 7:34pm |
What is the monitor resolution? That information is key to putting together the best system for your dollar.
Quote Reply Posted: 14 Mar 2017 at 2:43am |
Agreed, pick one of the Vanquish, the level 3 Best, with the gtx 1070 will be awesome on a 1080 p monitor. If you want or have a 1440p or 4K then the gtx 1080 or 1080ti is my pick.
You could go with a custom build, like Apollo for example, but you'll pay a couple hundred dollars more for the same performance. But, my more options. |
JadenLuck
Quote Reply Posted: 14 Mar 2017 at 12:10pm |
I have a 1080p monitor and would only play on 1080p or less for frames and idk if it helps but i play on a 144 hz monitor.
Quote Reply Posted: 14 Mar 2017 at 12:19pm |
The gtx 1070 will do it.
