Graphics card advice
Post Date: 2012-08-06
Buck View Drop Down
Avatar
  Quote Buck Quote  Post ReplyReply bullet Topic: Graphics card advice
    Posted: 06 Aug 2012 at 6:31am
My ATI(AMD) XFX 5870 Reference Cooler fan has seized after 2 1/2 years of use.
Looking for suggestions for a comparable replacement or slight upgrade.
Gaming on 23" 1920X1080.  The rest of system specs are in signature.
Yes I know an after market cooler is also an option.
Buck
Edited by Buck - 06 Aug 2012 at 6:33am
DS
i7 920 2.66GHz OC 3.75
EVGA X58 3X SLI
6GB DDR3 1600MHz
750W Corsair TX
500GB Western Digital
ATI Radeon HD 5870 1GB
Noctua Dual 120mm Fans High Performance Cooler
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Aug 2012 at 10:21am
I would search Newegg for 5870 coolers.  After market coolers pop up from $50 - $150.  Any chance the card is still under warranty?   If so a RMA might be the cheaper route.
When you asked for comparable replacement I'm assuming you meant the cooler.
Edited by bprat22 - 06 Aug 2012 at 10:23am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Aug 2012 at 10:29am
If you meant a card replace, then the HD 7850 for about $230 is very close if not a bit better in performance I believe.
Buck View Drop Down
Avatar
  Quote Buck Quote  Post ReplyReply bullet Posted: 06 Aug 2012 at 1:32pm
Sorry, Yep I meant replacement card.  Guess thats what I get for not proof reading my own post.
DS
EVGA X58 3X SLI
6GB DDR3 1600MHz
750W Corsair TX
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 06 Aug 2012 at 2:28pm
Not a problem.           After I thought about it, I figured that was it. I can't link from this tablet so google   Anandtech gpu bench....go to gpu2012 and select any two cards to compare.   The 5870 is there.    Good luck.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 07 Aug 2012 at 7:09am
Here is a link to the AnandTech Bench test.
AnandTech Bench Test
Buck View Drop Down
Avatar
  Quote Buck Quote  Post ReplyReply bullet Posted: 07 Aug 2012 at 3:49pm
Thanks for the replies so far gents.
AnandTech was a good read.  Makes me realize that I need to make more money if I want that Radeon 7970 or GTX690.
I got lucky.  On a whim I stopped by a little local Computer Repair shop.  They had a non working card that had the fan I needed.  They were willing to cannibalize and I got the fan for $10.  So I am back up and running.
Buck
DS
EVGA X58 3X SLI
6GB DDR3 1600MHz
750W Corsair TX
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 07 Aug 2012 at 4:02pm
$10 is lots better than $200 plus.   Glad it worked out.
