Graphics Card for Samsung 22incher
Post Date: 2007-09-03
Gary View Drop Down
Guest
Guest
  Quote Gary Quote  Post ReplyReply bullet Topic: Graphics Card for Samsung 22incher
    Posted: 03 Sep 2007 at 11:13pm
If I get the Samsung 22 inch monitor should I get the 8800 GTS 320 MB card or the 8800 GTS 640 MB card?
I know if I am not running resolutions above 1600x1200 or something like that, I should stick with 320 MB.
Suggestions?
thx,
Gary
srl50 View Drop Down
  Quote srl50 Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 12:54am
Gary, I just purchased the Sammy 22" and it is sweet. But, its resolution is 1680x1050. Pretty demanding resolution. You can run games at a lower resolution, but your images may seem a little stretched and squashed. The rig I'm building will have the 8800 GTX/768. I don't know what your budget is, but if you could go to the GTX series, I think you may be better off in the long run? Now, there are those here who are way more able and trained to advise you than me. This is just my opnion of course.
Steve
Never stop being a kid.
Q6600
8800 GTX 768
skyR View Drop Down
Avatar
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 04 Sep 2007 at 8:06am
Get the 320MB or get the GTX. Don't waste the money on 620mb for 1-5 fps increase.
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 05 Sep 2007 at 12:54am
Get the GTX.
Gary View Drop Down
Guest
Guest
  Quote Gary Quote  Post ReplyReply bullet Posted: 05 Sep 2007 at 11:35pm
Yep, I did! Ordered my system last night.
This page was generated in 8.105469E-02 seconds.
