Graphics Card? System?? Help!Post Date: 2012-04-08 |
e11eventoes
Newbie Joined: 06 Dec 2011 Online Status: Offline Posts: 71 |
Topic: Graphics Card? System?? Help! Posted: 08 Apr 2012 at 11:22am |
Been getting this issue every now and then. Sometimes it just lasts a few seconds. Then today it just wouldn't go away and eventually the entire system froze up and i had to do a hard restart by holding down the power button. The first restart, it wouldn't boot up and said that "overclocking failed, press F1 to setup". So i restarted a second time. I've got the latest nvidia driver 296.10. if it was a graphics card problem would the entire system lock and not allow me to click anywhere?? i just want to figure out the issue now instead of when i have to take work home. thanks!
http://vimeo.com/39972290 |
Quote Reply Posted: 08 Apr 2012 at 11:39am |
Overclock faults can be related to RAM. Try reseating all the ram sticks....try just one ram stickat a time It could be alot of things Worse case ..go into Bios and load default settings before DS overclocked until you can call DS. Best of luck
chasblock
Newbie Joined: 15 Feb 2012 Online Status: Offline Posts: 74 |
Quote Reply Posted: 09 Apr 2012 at 4:51am |
I got the overclocking failed message and turned out to be a bad stick of RAM.
Do what bprat22 suggested; take out one stick at a time. Also go in to Computer properties, make sure the right amount of RAM is showing up. |
e11eventoes
Quote Reply Posted: 09 Apr 2012 at 10:15am |
I'll try this out. but most important thing is the screen going nuts on me. that happens more times than the overclock message. actually the overclock message is the first time it's came up, and i'm guessing since i did a hard restart? the screen going nuts has been off and on for a month. this was the first that it stayed up and locked up.
e11eventoes
Quote Reply Posted: 11 Apr 2012 at 10:07am |
RAM's good. dont think it caused the screen to go berserk. i'll see again if it happens. thanks.
