Gurgling sound in liquid cooling system?Post Date: 2015-07-22 |
zpconn
Newbie Joined: 02 Jul 2015 Online Status: Offline Posts: 29 |
Topic: Gurgling sound in liquid cooling system? Posted: 22 Jul 2015 at 5:51pm |
I just got my brand new Bolt III. It's awesome!
Except there's a gurgling sound in the radiator. It's more or less constant. It doesn't go away when the fans are turned down or anything. Is this normal? It's fairly loud and is somewhat bothersome. I've never had liquid cooling before though so I'm not totally sure what to expect. If there's an issue with it, what should I do to resolve? |
hoserator
Quote Reply Posted: 23 Jul 2015 at 2:49am |
Hi zpconn,
Which cooling system did you order? If an open system with reservoir or has a liquid level window, make sure you have enough liquid in it. It shouldn't make any noise at all. |
Quote Reply Posted: 23 Jul 2015 at 3:10am |
If the fluid level is good like hoserator suggested, it could be just bubbles in the system from bouncing around during shipping. Give it a couple of days running to bleed the system. Check cpu and gpu temps with HWMonitor just to be sure.
Good luck. |
Tidgxor
Quote Reply Posted: 23 Jul 2015 at 6:57am |
One of my friend's had a liquid cooled rig that did this same thing for about 3 or 4 days after shipping. Then it stopped and hasn't done it since. Obviously keep an eye on your temps, but I'd see if the system is working out the shipping jumbles. Of course always feel free to give DS a call in the meantime.
FrankW
Quote Reply Posted: 23 Jul 2015 at 7:15am |
The Bolt 3 uses the Swiftech H220x cooler. You should be able to see the liquid level on the front of the cooler. You should note the level of the coolant and look at it often to make sure there are no leaks. As previously stated you probably have air in the system and should bleed the system.
You can Email Bryan at [email protected]. Tell him you want to bleed your H220x system. Bryan works for Swiftech. Ask him to send you the instructions on how to bleed the system. DS may have the same information. Frank Edited by FrankW - 23 Jul 2015 at 7:16am |
zpconn
Quote Reply Posted: 24 Jul 2015 at 9:54am |
Thanks for the responses so far.
I'm going to give it 4-5 days to just see if it will work out on its own before pestering DS. Since it's the Bolt model it's easy to lay on its side, so I'm trying to alternate between having it up-right and horizontal. I've noticed that when horizontal the gurgling nose is significantly quieter. Not totally gone, but nearly so. When I put it upright again, within an hour the gurgling sound will be back. I haven't seen any indications that the fluid level is depleting or anything. There are definitely some large visible air bubbles in the fluid indicator. When I get back this evening I may take a quick video so others can see and hear exactly what it's doing. Edited by zpconn - 24 Jul 2015 at 9:55am |
Alex
Quote Reply Posted: 24 Jul 2015 at 2:53pm |
If it does not go away after a few days, try this unit to bleed the system:
1. While it's sitting on the desk like normal and running, lift the system up from the front so that it's at a 45' angle. Keep it lifted for 1 minute to see if that helps bleed the air out. 2. If that did help, repeat the process of ra while and that should help. |
zpconn
Quote Reply Posted: 24 Jul 2015 at 3:53pm |
I've had success with turning it at an angle. In particular, turning it completely horizontal gets rid of most of the gurgling for ~15-30 minutes, but within an hour so far it's always back.
I took a video of what it was like when I got back from work today: https://www.dropbox.com/s/6uwnk4xx2x3fnnk/2015-07-24%2017.41.05.mp4?dl=0 It's completely upright in this video and had been running all day. After recording that, I laid it on its side and took a second video: https://www.dropbox.com/s/x35a8y6q6ldmczn/2015-07-24%2017.45.42.mp4?dl=0 You can see that the gurgling sound is nearly gone here but there appear to be rather large air bubbles. It's upright again and the gurgling sound is still mostly gone right now. However, if I listen very closely I can still hear it, and when I've tried this the last few times it always comes back so that it's just like the first video within an hour. |
Alex
Quote Reply Posted: 25 Jul 2015 at 12:59pm |
You will hear the system running, as there is a pump and motor running, especially when the fans are really quiet. What you also see are the bends the cooler has in it's tank to break the flow to mix the fluid when it drops in.
You should be ok from what I see now. |
zpconn
Quote Reply Posted: 25 Jul 2015 at 3:39pm |
Just to be clear, the gurgling sounds from the first video are normal and expected? It sounds almost like a fish tank. The second video shows what it's like immediately after tilting the computer around, but it always starts making the sounds from the first video within an hour.
I'm confused because another poster above said it shouldn't make any noise at all. |
db188
Quote Reply Posted: 25 Jul 2015 at 4:20pm |
that sound is caused by turbulence. when you bleed a system of air, you need to top off the fluid (i can see from your vids that you need to). try adding some. you shouldn't hear a "gurgling" sound at all in any orientation afterwards. tilt the thing at an angle, open the filler cap (to equalize), run the pump and let all of the air bleed out and then top off the fluid as you go. this takes a little time, but it will be worth it. also, make sure you place paper towels around the components and loop so you don't get any fluid on them.
to be perfectly honest, DS should've handled this during their breaking in period, and it makes me wonder what testing/QA they do with their custom/semi-custom water loops. Edited by db188 - 25 Jul 2015 at 4:34pm |
