Help Monitor is Red tinted
Post Date: 2015-05-05
towerofpain View Drop Down
  Quote towerofpain Quote  Post ReplyReply bullet Topic: Help Monitor is Red tinted
    Posted: 05 May 2015 at 3:47pm
so I just gotten my vanquish 3 level 2 today i was told that i needed to buy a adapter to connect my monitor,my monitor that has vga blue cord so i bought this adapter called DVI TO VGA (HDD)Adapter also has a name of DVI-A Male to HDD/VGA Female i connected that part to back bottom of my comuter and the blue vga onto it my monitor works but the whole screen is tinted red color my monitor works perfecty on my other computer i don't know if its that adapter i bought or something else please help
Pacesetter View Drop Down
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 05 May 2015 at 4:15pm
If you have a flat panel monitor the second one in the picture should be the connector you have. You will need a DVI-I Dual Link cable to attach it to the video card.
If you have an old CRT monitor then the only port will be as the bottom one in the picture. (VGA)
I think you have an incompatibility going due the adapter not using all the signal pins.
NOTE: Single link and Dual link are not compatible for connections. The DVI-I Dual link will work on the DVI-D dual link.
The difference is that DVI-I carries both HD and analog signals where the DVI-D just carries analog signal.
Let me know whether or not this helps. - If not I'll need more info on what video card and monitor you have.
ALSO I believe the adapter needs to be connected to the monitor not the video card.
Connect a DVI-A compatible monitor to a VGA HDD15 port on your computer. Or connect a VGA monitor to the DVI-A port on your PC. This adapter switch hits.
•Connect DVI-A to computer's DVI-A output jack, use a VGA plug cable to connect it to VGA monitor
•Connect DVI-A to monitor input, use a VGA plug cable to connect it to computer VGA input
Edited by Pacesetter - 05 May 2015 at 4:20pm
Vanquish II Ultimate.
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 05 May 2015 at 5:21pm
thanks for helping me ok so
the second one on the pic DVI its whats back of my computer that I need to use to use my monitor the adapter I bought its the 5th one Dvi-A_DVI analog I have that connected onto the second one on the pic and my vga is attach to the adapter ,
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 05 May 2015 at 5:23pm
oh also the back of my monitor just has the blue vga witch is the last on your pic list and a white Dvi
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 05 May 2015 at 5:27pm
Sounds like the adapter is the problem.
What you need is a DVI-D or DVI-I to VGA adapter.
Did you check in the accessories box from DS? They usually include one in there.
EDIT: The white DVI port on the monitor should be a DVI-D port. (4th one in the picture)
A DVI dual link cable should work also.
Edited by Pacesetter - 05 May 2015 at 5:30pm
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 05 May 2015 at 6:51pm
ok there was a Dvi-i second one on the pic I plug it in the back with the vga attach to it on the back and still my monitor is screen also I got me a new Dvi-D 4th one on the pic use that instead the vga on my monitor and connected the dvi-D to the back of my comuter and that made my monitor go black really appreciate the help u are giving nothing I do works :(
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 05 May 2015 at 8:10pm
I was pretty sure the DVI adapter would do it.
Where the screen went black with the DVI-D, make sure you plugged it in to the video card it's self and not the on board video. The black screen suggests no signal.
Let's try this:
Turn off and unplug both the computer and monitor for 2 minutes - then plug in the monitor and turn it on, then plug in the computer and turn it on and let it boot up. This should clear any problem with the computer identifying the monitor.
If you still have the red tint, go to control panel (search - control panel) and select the display. On that window, on the left side click 'calibrate colors'. Follow the directions adjusting where you need to until the end and click finish. Restart the computer and see if the problem remains.
We are on the right track but this train seems to have a mind of its own.
If this is no help, I'd suggest calling DS when they open in the morning.
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 05 May 2015 at 8:38pm
ok my monitor is now working yay but nothing was working so i restart my computer press F8 and did a refresh witch really sucked cause it unitstall a lot of things that came with my computer like the video card was gone i had to reinstall it on the nvida website
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 06 May 2015 at 10:06am
Glad ya got it going. This was one of the strange problems that defies logic.
Sounds like Windows chose a different color profile for your computer/monitor. The refresh set it back to the default.
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 06 May 2015 at 1:54pm
ok I been having problems still I submit a ticket and today I spended 2 hours on the phone with them after doing everything they told me my computer is perfectly fine but it appears it is my monitor witch its 7 years old aint working to well with my desktop so now I have to wait next week to buy a new monitor
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 06 May 2015 at 5:00pm
Thanks for the update. It sounds like once you get a monitor you'll be set.
Happy gaming!
  Quote towerofpain Quote  Post ReplyReply bullet Posted: 06 May 2015 at 9:22pm
quick update just got a new monitor at best buy im using HDMI cables and holy crap it looks amazing!!!! thanks a lot for your helping me out here !
  Quote Snaike Quote  Post ReplyReply bullet Posted: 07 May 2015 at 4:14am
lol.. yea, The difference between HDMI and VGA is on an exponential scale....
Cheers!
Edited by Snaike - 07 May 2015 at 4:14am
  Quote Pacesetter Quote  Post ReplyReply bullet Posted: 07 May 2015 at 12:42pm
Super!
Now you can get on to enjoying that computer and some fine gaming.
Glad we were able to get you up and running.
