Help on this build??
Post Date: 2009-02-17
pascal333 View Drop Down
  Quote pascal333 Quote  Post ReplyReply bullet Topic: Help on this build??
    Posted: 17 Feb 2009 at 5:04pm
Is the inclusion of the Raptor and the 285 video (as opposed to 500GB HD and the 265 GPU) worth the $ for occasional gaming? And how important is the 1000W power supply. I want to cut corners where possible without cutting stability.
I could save some money by using the Coolermaster HAF case and standard fans...but how much of a problem is spilling from the top? I use the case for a side table...it does not sit under a desk.
Help!
Ticket Number: 248549
Chassis Model: Digital Storm 850Si
System Memory: 6GB DDR3 1333MHz Corsair Dominator DHX (High-Performance)
Power Supply: 1000W Silverstone OP1000-E (Dual/Triple/Quad SLI Compatible) (Silent Edition)
Card Reader: - No Thanks
Hard Drive Set 2: Multimedia\Data: 500GB Western Digital (16MB Cache) (7200 RPM) (SATA)
Video Card: 1x NVIDIA GeForce GTX 285 1GB (Includes PhysX Technology)
LCD Display: - No Thanks
Avatar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 5:20pm
you lost me on 265 GPU, what is that.
when you say occasional gaming, what resolution are you talking about, how often and how much is the smoothness of the game important to you?
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 6:27pm
Yes!! That was supposed to be a 260, not a 265...When does the 265 come out?Cool
  Quote pascal333 Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 6:35pm
For resolution, let assume 1024x1280. Smoothness is important. However I am new to gaming (don't currently have a gaming system or play) and so am guessing 8 hours a week?? I know this could be wildly off but it seems a good starting point. I will be interested to see how a good game and great system influence this!
Avatar
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 7:08pm
just stick with the 285
its a beast and youll neever have to go SLI at that res
Avatar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Feb 2009 at 9:50pm
then for your resolution this is what you need:
here you go Ticket# 248877 --- Price: $2640 (To see this build click here)
Video Card: 1x NVIDIA GeForce GTX 260 896MB (216 Cores) (Includes PhysX Technology)
This page was generated in 7.617188E-02 seconds.
