Help, put in new graphics card and no display!Post Date: 2016-02-28 |
Acecateer
Newbie Joined: 15 Jan 2016 Online Status: Offline Posts: 25 |
Topic: Help, put in new graphics card and no display! Posted: 28 Feb 2016 at 2:45pm |
It's my first time tinkering with a computer, I upgraded my power supply and graphics card. I upgraded my power supply to an evga 750 watt gold and my graphics card to an MSI r9 390 8 GB. Also note that I used an anti static wristband the entire time while working on it. I plugged the hdmi into the graphics card and booted up but there wasn't any display at all. I'm freaking out, did I just ruin my computer!? Everything seems to be working, the fans are spinning and the motherboard is lighting up as well as allowing peripherals to work. Please help I don't know what to do!
Acecateer
Quote Reply Posted: 28 Feb 2016 at 2:47pm |
Should I have used cpu2 instead of cpu1 when plugging in the power cable for the cpu?
Quote Reply Posted: 28 Feb 2016 at 2:48pm |
Double check the PCIE power connectors from the power supply to the graphics card. The card's fan is turning?
Acecateer
Quote Reply Posted: 28 Feb 2016 at 2:51pm |
The graphics card is fully on, I plugged both power connectors in properly.
Htoler
Groupie Joined: 07 Feb 2009 Online Status: Offline Posts: 241 |
Quote Reply Posted: 28 Feb 2016 at 2:57pm |
try resetting your BIOS it prolly has stored info for your old video card drivers
Acecateer
Quote Reply Posted: 28 Feb 2016 at 2:58pm |
How do I do that?
Quote Reply Posted: 28 Feb 2016 at 3:00pm |
I would remove and then re seat the graphics card. If it's getting power and its seated properly in the correct PCIE slot then it could be a bad card. Or the HDMI cable but probably not if it was working before the card swap.
Do the caps lock and num lock keys light when pressed? Just making sure the mobo is actually loading the OS. Does your mobo have integrated graphics? If so, try using that just to check the mobo, drives, etc. Not sure if you swapped both the supply and card at the same time, but it's best to do one at a time, checking each before moving on. Just less to troubleshoot. |
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:01pm |
prolly easiest way would be to remove the round battery on motherboard leave it out for say 30 secconds put it back reboot
Acecateer
Quote Reply Posted: 28 Feb 2016 at 3:03pm |
Yes, the caps lock and num lock keys light up. And it doesn't have integrated graphics as far as I know. It's the motherboard that comes with the vanquish 4 level 1. I guess I'll try taking the card out and putting it back in. |
Htoler
I had this happen with My first DS system thought the mobo fried but was bad video card but i put in a different card and like you everything powered up no display until I reset bios
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:10pm |
I just looked up the 110 motherboards should have integrated graphics look for HDMI connection above usb speeker and earthnet connections
Acecateer
Quote Reply Posted: 28 Feb 2016 at 3:13pm |
I tried plugging it into that earlier and still nothing |
Acecateer
Quote Reply Posted: 28 Feb 2016 at 3:14pm |
Still no display even in motherboard hdmi slot, it could be that I need to reset my bios but what's the best way to do that? I don't have anything but my bare hands to do it. And an anti static wristband of course.
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:17pm |
if you have the old video card clos reinstall it and see if get display if do let it fully boot up go into device manager and unistall video card drivers the shut down install new card and reboot
Edited by Htoler - 28 Feb 2016 at 3:17pm |
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:18pm |
do you have the motherboard book ? do you know if you have the Asus 110 mobo or Gigabyte 110
Acecateer
Quote Reply Posted: 28 Feb 2016 at 3:26pm |
Okay so I put in my old graphics card and it booted just fine and is working. I must have to reset my bios, I'm not ready to accept that the card is bad just yet. So should I uninstall the nvidia drivers? I'm switching from nvidia to amd. Please tell me everything I need to do before putting my new card back in |
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:30pm |
oh most definately go into device manager then to videocard uninstall drivers shut down install new card reboot
Edited by Htoler - 28 Feb 2016 at 3:31pm |
Htoler
Quote Reply Posted: 28 Feb 2016 at 3:37pm |
if this dosnt work follow this link
http://ccm.net/faq/1692-installing-a-new-graphics-card |
Acecateer
Quote Reply Posted: 28 Feb 2016 at 9:00pm |
I ended up fixing it hours ago. I missed one tiny cable that I needed to plug into the power supply and it wasn't plugged in that well to the PCI slot. Thanks for all the help everyone though.
Snaike
Quote Reply Posted: 29 Feb 2016 at 1:23am |
For your first time tinkering, only to be beset by a missed 'one tiny cable", I would say that was a success. You probably learned quite a bit from this experience and now have a better, faster machine that you helped create.
So, Congrats!, and enjoy the new power. |
Quote Reply Posted: 29 Feb 2016 at 2:16am |
Htoler
Quote Reply Posted: 29 Feb 2016 at 5:57am |
awesome its now up and running
