HELP with AventumPost Date: 2013-01-10 |
adam2012
Newbie Joined: 14 Dec 2012 Online Status: Offline Posts: 11 |
Topic: HELP with Aventum Posted: 10 Jan 2013 at 12:29pm |
hi
i done build my new pc with DS i chose the spec here is the config (774040) and i need ur help and ur opinion and suggestions the pc i want it for max gaming for long time with the best cooling and guys do u recommend this cooling 1- Digital Storm Aventum Liquid Cooling System: CPU + Video Cards + Chipset OR 2-H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Quad SLI/CrossFire Video Cards & Chipset and can DS put me the 2400MHz Corsair Dominator Platinum DHX instead of 2133MHz Digital Storm Certified Performance Series with 32 GB so that my ram will be 32 GB 2400MHz Corsair Dominator Platinum DHX or there will be problem with that and about the (APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector) is it useful or i remove it ty guys and i hope u help me |
Quote Reply Posted: 10 Jan 2013 at 1:17pm |
Hi adam2012........DS can pretty much install any ram.
I don't believe the stage 6 cooling is an option with Aventum. For the money you're spending and their Aventum system, I would recommend talking to DS directly. A rig like this you want to get right. This is probably alot more than you need for gaming but the Aventum is a luxury rig for those that demand the best. Good luck. |
tju76
Senior Member Joined: 06 Mar 2012 Online Status: Offline Posts: 804 |
Quote Reply Posted: 10 Jan 2013 at 1:36pm |
What are your intentions with this build what will be the uses
adam2012
Quote Reply Posted: 10 Jan 2013 at 1:43pm |
hi bprat22
ty for ur comment i know stage 6 is not in aventum i talk generally which is better ty for help about the ram about what i need in gaming u rly think that is more than enough may i know why i mean games now days like battlefield 3 and crysis 2 need lots of ram and high vga and processors and i want to play 3d too and can u give me ur suggested build for ultimate gaming performance and for games in future as well with the max cooilng coz i have warm room in summer |
adam2012
Quote Reply Posted: 10 Jan 2013 at 1:58pm |
hi tju76
my attention for main use gaming in ultra settings with no lag and play 3d games and play games in the future in ultra settings for long time so that's why i chose most of the stuff as the ultimate thing so that it last with me for long while beside the normal stuff watch 3d movies and normal movies browsing and so and i was want to ask the expert her i chose the Asus Vg287h monitor is this game change the normal movies and normal games into 3d or what and how to watch 3d movies on it what software i need if someone can help me |
Quote Reply Posted: 10 Jan 2013 at 2:20pm |
I can' t cut/ paste right now on my tablet, but here's a config to check out. It has the stage 6 cooling you asked about and is nice cooling and the 800d case made for water cooling.
Config # 774080 Cost $ 5869 You didn't mention how many monitors in 3D. If triple monitor then this tri-sli gtx 680 will be real nice. If a single 3D monitor then drop to sli, 2x gtx 680 and adjust the stage 6 cooling to match. You could even go with a 2gb vram cards for a 1920x1080 monitor. The 1200watt psu is all you need. The 1050 hx for sli. And 16gb of ram is plenty for gaming. I don't 3d game/ movies so can't help with software, etc. Don't get me wrong, the Aventum is an awesome rig and if its in the budget then go for it. But the number of monitors and their resolutions determine the video cards you need. Hope this helps. Edited by bprat22 - 10 Jan 2013 at 2:24pm |
adam2012
Quote Reply Posted: 10 Jan 2013 at 3:11pm |
no i want just one monitor only
the one i chose i great for me i donot like play with 3 monitors nice build btw but i like aventum more |
surf71zx
Groupie Joined: 07 Jan 2011 Online Status: Offline Posts: 485 |
Quote Reply Posted: 10 Jan 2013 at 3:54pm |
DS just came out with the aventum 11 I would wait for that to be available in 1 to 2 months. Just unveiled at the 2013 CES show in Las Vegas 2 days ago. Check it out.
adam2012
Quote Reply Posted: 10 Jan 2013 at 4:42pm |
can u give me link to any video or any thing about it ?
Asangard
Quote Reply Posted: 10 Jan 2013 at 6:39pm |
adam2012,
Here is a link to an article about the Aventum II with some pics in it. I hope this helps, |
adam2012
Quote Reply Posted: 11 Jan 2013 at 3:15am |
Hi Asangard
ty so much for the great article i think i will wait to cehck it ty guys for help |
