Help with configurationPost Date: 2018-02-23 |
paulwhiskey33
Newbie Joined: 23 Feb 2018 Online Status: Offline Posts: 3 |
Topic: Help with configuration Posted: 23 Feb 2018 at 10:11am |
I'm new to customizing a PC is there anything in here that I should upgrade to work better with anything else? Any ideas or tips is much appreciated!
System Configuration: Chassis Model: Digital Storm Lumos Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i5-8600K (6-Core) 3.60GHz Motherboard: MSI Z370 GAMING PRO CARBON AC (Wi-Fi) (Intel Z370 Chipset) (Up to 3x PCI-E Devices) System Memory: 8GB DDR4 3000MHz Digital Storm Performance Series Power Supply: 750W Corsair RM750x (Fully Modular) Expansion Bay: - No Thanks Optical Drive: External USB - DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs) Storage Set 1: 1x SSD M.2 (250GB Digital Storm Performance Series) Storage Set 2: 1x Storage (2TB Seagate / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 Ti 11GB (Performance Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (CPU Only) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Green Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System) Cable Management: Exotic Cable Management - Green - (Cable Combs with Custom Color Sleeved Extension Cables) Chassis Fans: Corsair LED Airflow Performance Edition (Green) Fans Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: Option Not Available CPU Boost: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system Operating System: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks |
Quote Reply Posted: 23 Feb 2018 at 3:50pm |
Build looks good. However, without knowing what it’s used for or what games and the monitor resolution, we can’t know what video card or cpu is best.
Cretae
DS Veteran Joined: 22 Mar 2010 Online Status: Offline Posts: 7330 |
Quote Reply Posted: 24 Feb 2018 at 4:09am |
What bp said.
Not a good idea to overcook your video card. Basically won't matter much but will stress the card and raise temps. |
paulwhiskey33
Quote Reply Posted: 26 Feb 2018 at 4:31am |
I'm using it for gaming. I switched it up and already ordered it. I play all types of games I just wanted to switch from console to pc. Here is what I ordered though and I hope I didn't mess it up lol. I can get a new monitor or upgrade whatever I need to just let me know and thanks!
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7-8700K (6-Core) 3.70GHz Motherboard: ASUS PRIME Z370-P (Intel Z370 Chipset) (Up to 2x PCI-E Devices) (No SLI Support) System Memory: 32GB DDR4 3000MHz Digital Storm Performance Series Power Supply: 750W Corsair RM750x (Fully Modular) Expansion Bay: External USB Digital Media Card Reader Optical Drive: External USB - DVD/CD 8x Multi-Drive (Writes and Reads DVDs, CDs) Storage Set 1: 1x SSD M.2 (500GB Digital Storm Performance Series) Storage Set 2: 1x Storage (3TB Seagate / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless USB ASUS N13 (Supports 802.11n/g/b) Graphics Card(s): 1x GeForce GTX 1080 8GB (Performance Edition) (VR Ready) (ETA End of February) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (CPU Only) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Green Fluid + Clear Tubing (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: Option Not Available CPU Boost: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system Operating System: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Game: - No Thanks Display: Asus 4K Ultra HD 28 inch PB287Q Series (10-bit Color) (1ms Response Time) (3840 x 2160) |
Quote Reply Posted: 26 Feb 2018 at 4:47am |
Looks good and Congrats
For 4K gaming, the gtx 1080 Ti in your original build is the recommended. There is a chance the gtx 1080 on backorder will not be filled. The card, from what I’ve read, has stopped production because of the newer Ampere gtx 2080/2070, tentative name, will be released end of March. |
paulwhiskey33
Quote Reply Posted: 26 Feb 2018 at 7:44am |
Yea it did say something about the backorder. I will look into the ti thanks!!!
