Impressed with Aventum 3 CoolingPost Date: 2016-02-21 |
db188
Topic: Impressed with Aventum 3 Cooling Posted: 21 Feb 2016 at 6:23pm |
I've had my system for a few months now and i have decided to start performance tweaking.
i've focused recent efforts on tweaking the 2xAsus 980ti Strix under EK water blocks as part of my single loop (cpu+2xgpu) config. the Intel I7-6700K is only oc'd to 4.6GHz and not optimized as of this testing. the mobo is Asus' Deluxe Z170. the tweaking tool used is Asus' GPU Tweak II version 1.1.8.3, and is supposedly W10 compatible. The Settings: the GPU Boost Clock = 1400 MHz Max GPU Voltage = 1213 mV Memory Clock = 8000 MHz or 8GHz Fan Speed = controlled by the DS Control Center and set to run on "Auto". Power Target = 110% GPU Temp Target = 83C Frame Rate Target = N/A the benchmarking software used was Unigine's Heaven (free version). i set the resolution to 1920x1080p (still waiting on my 1440p Ultra Wide) with "Ultra" settings enables. no anti-aliasing. Observations: FPS was between 160-200 consistently throughout the test. temps on primary gpu never jumped over 43C. utilization of primary gpu was 99%. the fans in my system never even ramped up. noise was as normal (which is to say very tolerable). i was able to achieve 1615 MHz oc (as read from the Heaven real time benchmark); however GPU-Z reported 1501 MHz frequency. i tend to believe GPU-Z and HARDOCP got similar actual frequency numbers. Screen shots to show GPU-Z report: , and the mobo in the AV3 is rotated 90 degrees, so the cpu sits at the lowest point in the loop, while the gpu's are at the top. i've seen cpu temps hit 65-75C at times under load, while the gpu's remained ultra cool. HARDOCP tested this video card utilizing the same oc'ing software and wile speed/performance results were almost identical, their card wasn't under water (it utilized the Asus custom air cooling unit that comes with the card). their temps were in the 70's, while mine (under the 3 rads that come with the DS top of line cooling) never rose above 43C. that's some impressive cooling! just wanted to share for any interested in such things. i hope others can post their experiences with DS performance and cooling. Edited by db188 - 21 Feb 2016 at 6:27pm |
Aventum 3
eeekman
Newbie Joined: 06 Oct 2015 Online Status: Offline Posts: 95 |
Quote Reply Posted: 22 Feb 2016 at 4:56am |
I have an Aventum 3 also with 2 x Asus Strix.
When I purchased the system, I decided not to spend the extra cash on water cooling the GPUs. What a mistake! The primary GPU would reach temps of 92C and throttle down the GPU speed. I manually cranked up the fan speed to 76% and the temps still went up to 84C. The fans were so obnoxiously loud I couldn't stand it. I sent the cards back to DS to have the water blocks installed and am patiently waiting their return. Moral of the story: Water cool the GPUs. I look forward to the awesome cooling that you speak about. Are you using the stock Aventum 3 radiators? Edited by eeekman - 22 Feb 2016 at 4:57am |
Aventum 3
i7-6700k @ 4.6GHz 32gb 3200MHz RAM Gigabyte Auros Waterforce Extreme 1080ti |
Quote Reply Posted: 22 Feb 2016 at 8:17am |
Excellent info and thanks for sharing.
I would think, from eeekman's experience and the general case layouts, that the Aventum 3 with sli Strix or a similar setup, are better water cooled than on air. If someone doesn't want to put the cards under water then the Velox with its side fans would be a better setup for gpu cooling. Unless of course someone just wanted the Aventum 3 case, which is an awesome case. Too bad the Aventum 3 didn't have the option for a side fan or fan located between video cards and drive cages to kick the heat out. Just my thoughts. |
SnowandSand
Groupie Joined: 21 Jan 2013 Online Status: Offline Posts: 278 |
Quote Reply Posted: 22 Feb 2016 at 10:23am |
db188,
Did the GPU tweak software come on one of your ASUS disks? I'm looking to start testing out the cooling setup in my Hailstorm II (obviously not on the lvl of the AV3 lol) and wanted to see what these Strix cards can do. |
Hailstorm II(Retired)
R7 2700x 16GB Team Dark Pro @ 3200 CL14 Asus x470 CH VII Hero Corsair Hx1000i 1000W PSU 250GB Samsung 850 EVO 1TB & 6TB WD - Black Edition 2x GTX 980TI Strix Hydrolux Stage 3 |
Quote Reply Posted: 22 Feb 2016 at 11:52am |
Until db comes back.... I would download the latest version from the Asus website.
eeekman
Quote Reply Posted: 22 Feb 2016 at 12:57pm |
The side fan can be added to the Aventum 3 I just chose not to do it. I could have even ordered a new side panel with the fan cutout but it was a good excuse to spend the money and have the GPUs set-up for water cooling.
GPU Tweak is on the CDs that come with the video cards or it can be downloaded from Asus' website. |
Aventum 3
Quote Reply Posted: 22 Feb 2016 at 1:02pm |
Good to know about the side fan.
db188
Quote Reply Posted: 22 Feb 2016 at 3:12pm |
Aventum 3
SnowandSand
Quote Reply Posted: 22 Feb 2016 at 7:56pm |
So I did the same OC settings as you but when I ran the same benchmark I did it at 1440p and got:
FPS Avg : 107.5, FPS Max: 203.5, FPS min: 38.3, and score of 2707, Max GPU Clock 1513 MHz, Max GPU Voltage 1212mV, Max Mem Clock 8002 Max GPU Usage 99%. The temp spiked at 43c but averaged in the 30's. So I would say the Hydrolux lvl 3 works quite well in the Hailstorm II as well lol. Edited by SnowandSand - 22 Feb 2016 at 7:57pm |
db188
Quote Reply Posted: 22 Feb 2016 at 10:40pm |
Aventum 3
db188
Quote Reply Posted: 22 Feb 2016 at 10:46pm |
Aventum 3
SnowandSand
Quote Reply Posted: 23 Feb 2016 at 6:38am |
Yeah I was surprised by that too. As far as the rads all I could see on them was XSPC on the side, but I'm not sure which models. I forget the size, I believe that they might both be 360's(one on the top and one in the bottom compartment). The card's were running in the upper 30's when I did look at the bench mark running but my 8 month old pulled me away for most of it lol. This weekend I might try and bump the CPU OC up a bit. It came at 4.5GHz from DS but I want to see what it can do lol.
Edited by SnowandSand - 23 Feb 2016 at 6:40am |
db188
Quote Reply Posted: 23 Feb 2016 at 6:07pm |
Aventum 3
eeekman
Quote Reply Posted: 24 Feb 2016 at 11:05am |
db188 -
Are you using all stock case fans in your Aventum 3? |
Aventum 3
db188
Quote Reply Posted: 24 Feb 2016 at 6:10pm |
no, i'm using Cougar's.
Aventum 3
eeekman
Quote Reply Posted: 05 Mar 2016 at 5:17am |
Finally installed my newly water cooled video cards.
Going to let it run for a few days before topping off the reservoir and getting the micro bubbles out. DS did a great job (of course) packing and shipping me everything I needed (fittings, fluid, hose) to re-install them into my Aventum. Installation was a breeze and only lost about 2 drops of coolant during the install thanks to the quick connects. |
Aventum 3
