Just got my system, have a monitor question.Post Date: 2016-06-22 |
Author | ||
Vertebreaker
Newbie Joined: 28 Apr 2013 Online Status: Offline Posts: 26 |
Topic: Just got my system, have a monitor question. Posted: 22 Jun 2016 at 3:25pm |
Hey all, I just got my new computer today (a really great SLI 1080 build) and so far the thing is running great, as expected. However, I'm running into an issue with the resolutions allowed by my monitor.
I picked up the Dell P2715Q monitor, as I heard it was a solid 4K@60 monitor. However, it should also be capable of 1440p@144hz, but I'm not seeing that in my adapter options. I'm limited to 60fps no matter which display resolution I choose, even 1080p, and this is with a mini-Displayport connection. I also made sure the monitor driver was installed, but no go. Any tips on getting this monitor working at the 144hz it should be able to reach? Thanks! |
SalJuice
Newbie Joined: 02 Apr 2016 Online Status: Offline Posts: 8 |
Quote Reply Posted: 22 Jun 2016 at 4:07pm | |
Mini displayport isn't capable of 144hz. I think you can just buy a mini DP > DP cable for cheap on Amazon. The other option is to pick up a dual link DVI - up to you. Single link DVI won't cut it either.
Just to add...I'm jealous of your 1080 SLI build! Enjoy! Edited by SalJuice - 22 Jun 2016 at 4:08pm |
Quote Reply Posted: 22 Jun 2016 at 4:31pm | |
AS far as I know Dell monitors and specially the one you mentioned is listed at 60Hz. Its an IPS panel, which has great image quality but its limited in refresh rate to 60Hz.
Vertebreaker
Quote Reply Posted: 22 Jun 2016 at 4:47pm | |
Thanks! Should keep me busy for the next few years! ;) Everything I've read has said mini-Displayport has the same capabilities as a regular Displayport. There's no way my internet could have conflicting information, right? I'm running mini from the monitor to Displayport on the 1080, fyi. |
Vertebreaker
Quote Reply Posted: 22 Jun 2016 at 4:50pm | |
I just checked the User Guide and I think you're right, I only see a maximum of 60hz. That sucks. I'm not planning on playing in anything but 4K, but I wanted the option to bump it down to 1440p if I wanted to play something at 144hz. Bummer. Might consider exchanging it, but it looks so good. |
Quote Reply Posted: 22 Jun 2016 at 5:04pm | |
Not sure if there are any IPS panels that have a higher refresh rate at 1440p, but if there is, its gonna cost you a pretty penny. IPS has the best image quality, that is why it looks so good.
Edited by DST4ME - 22 Jun 2016 at 5:04pm |
SalJuice
Quote Reply Posted: 22 Jun 2016 at 5:05pm | |
I could be wrong, but back when I first bought my BenQ 144hz, I remember reading that I'd need a mini DP to DP adapter. That said, I just ended up going with the dual link DVI since the monitor ended up coming with one, thankfully. Looks like you have a different issue though. I'll say this, 144 vs 60 is quite a difference. Not as huge as 30 to 60, but 144 is buttery smooth. I would definitely, if you could, return that one and get a proper 144hz monitor. |
Vertebreaker
Quote Reply Posted: 22 Jun 2016 at 6:13pm | |
Thing is, I would have to give up the IPS display, and I don't know if I want to trade 4K for 1440p, even if 1440p can run at 144hz. I'm probably stuck waiting for a monitor that can do 4K at 120hz or 144hz. Edited by Vertebreaker - 22 Jun 2016 at 6:14pm |
Quote Reply Posted: 22 Jun 2016 at 8:42pm | |
LOl I'm still waiting for an IPS that can do 4k at 144Hz |
Quote Reply Posted: 23 Jun 2016 at 2:24am | |
Wait looks like one might be in the works:
"this new 4K UHD (3840 x 2160) monitor uses a display with IPS technology. The panel, sourced from AU Optronics, is said to provide "stunning photo-realistic visuals". As headlined, the screen can refresh at a 144Hz which helps give the viewer the impression of smoother movement on screen." Edited by DST4ME - 23 Jun 2016 at 2:30am |
Goku1910
Groupie Joined: 08 Apr 2015 Online Status: Offline Posts: 121 |
Quote Reply Posted: 23 Jun 2016 at 5:14pm | |
I just got my Asus MX25AQ and love it's IPS glory. I hear it can be tweaked up to 75Hz but I'm perfectly fine at 60Hz. Being a console player most of my life 60 FPS is satisfying.
Bolt 3!
Stage 1: 6/2/16 Stage 2&3: 6/7/16 Stage 4&5: 6/11/16 Stage 6: 6/16/16 Stage 7&Shipped: 6/24/16 |
Quote Reply Posted: 23 Jun 2016 at 5:40pm | |
I think most of us here love the IPS and want faster refresh rate with IPS.
