Looking for help build a rig... ^_^Post Date: 2012-05-03 |
Stealth1984
Newbie Joined: 03 May 2012 Online Status: Offline Posts: 26 |
Topic: Looking for help build a rig... ^_^ Posted: 03 May 2012 at 11:30pm |
My budget for this system is around $2200-2400 (2400 being absolute max). This is only for the PC itself. I will be purchasing the monitors and peripherals separately. Expectations: - A fast-booting, cool and quite running machine. - Case-wise, simple is best in my opinion. Don't need flashing lights and such. (really like slade and hailstorm cases) - Great processor, memory, and GPU a must. Usage: -Extreme gaming capabilities. Playing Diablo III, Guild Wars 2, etc. want to be able to run games on highest settings. -Handle a variety of graphic design and photo editing software at fast speeds (Photoshop, Lightroom, etc...) -Able to process many applications simultaneously without memory or processor constraints. Special Needs: Would like to avoid water cooled systems, I don't want to worry about that maintenance. I don't mind adding more fans in an effort to keep things running cool. I want my system to run cool and quietly. I am planning to buy this PC in July as I currently live in Japan and won't be moving back to the states til the 1st of August. Greatly appreciate all help and recommendations. Thank you for your time and consideration. -Stealth Edited by Stealth1984 - 03 May 2012 at 11:31pm |
Asangard
Quote Reply Posted: 04 May 2012 at 12:46am |
Stealth1984 welcome to the forums.
We really need to know what resolution you are going to game at. The higher the resolution the more graphics power you need. Also you mentioned monitors in you post. Do you plan on gaming on multiple monitors and if so how many? Again welcome.
Stealth1984
Quote Reply Posted: 04 May 2012 at 6:16am |
Asangard, thanks for the welcome!
I plan to game on dual monitors. These monitors specifically: ASUS VE276Q Black 27" 1920X1080 2ms Full HD HDMI The resolution is: 1920 x 1080 GPU is not something I want to skimp on. I don't necessarily need the newest one on the market. But I want a card I wont have to upgrade for 3 years or so. Any other useful information I can provide? Sorry, I am a bit new to all this. |
Quote Reply Posted: 04 May 2012 at 9:00am |
Hi Stealth1984... here's a custom build to check out and I'll explain
Config # 684062 Cost $ 2361 Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard) Motherboard: ASUS SABERTOOTH Z77 (Intel Z77 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Phanteks PH-TC14PE Extreme Performance H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty The HafX case is the best air cooled case. The Slade, 550D, case is nice but the cooling is much less. To cool the 550D better, a smaller side and top fan might have to be added, which is more noise and takes away it's quiet feature by removing the top and side insulating cover. It might work as is but cooling is the most important part of a case . I understand aesthetics, but we always recomment the HafX and after that it's your choice as always. I tried to work in the X79 platform for your editing, etc but for your budget couldn't do it. The Phanteks air cooler is very reliable and cools great and with the oc stage 2, is a great fit. The gtx680 is great, the only better the gtx 690.. To game on a dual monitor would require either the 680 or a sli setup. Even with the 680, the games you mentioned would do great but games like BF3 and Metro 2033 would drop into the 40's or 50 fps at ultra settings. For your budget the ODE lvl 4 would be a great choice . For $2099 you would get the same gaming performance as this build, plus a SSD and blu-ray player. The ODE doesn't have sli capability. See what you think and good luck. |
Stealth1984
Quote Reply Posted: 04 May 2012 at 9:44am |
Bprat22, thank you very much for taking time to come up with this configuration. It looks fantastic!
I have a couple of questions, if you don't mind. 1. I really want a fast boot/shut-down so would a SSD be worthwhile? I don't mind spending a little extra if it would be worth it. 2. Also, does it make a big difference gaming-wise to go with 2000mhz ram instead of 1600mhz. The price seems pretty significant. Is it worth it from a performance standpoint? 3. As for dual monitor gaming, I think I misspoke. I will be running a dual monitor setup, but only gaming on one screen. The other will be used for internet browsing and such while gaming. Does that make sense? Sorry for any confusion in wording. Also, with the GTX680, will I be able to run both monitors HDMI? or will one be HDMI while the other uses a DVI port? 4. In regards to case, would I be able to switch out the CM case for the Corsair 650D and still have appropriate cooling? I really like the minimalistic look of the Corsair case. 5. Lastly, forgive me, but what is the X79? Thanks again for your time and help. It is greatly appreciated. :) Edited by Stealth1984 - 04 May 2012 at 9:48am |
Stealth1984
Quote Reply Posted: 05 May 2012 at 2:32pm |
Bump for help with questions :p
Quote Reply Posted: 05 May 2012 at 3:10pm |
Hi Stealth1984......sorry for slow response. My internet connection has been problematic. Just as I get here the thing goes haywire. Anyways.....for fast boot times SSD is the way to go. Instead of a two minutes to boot., it happens in 20 seconds. You'll never see the difference in ram speed. Go cheaper. I can' t be sure but I don' t think 680 will do dual hdmi.. The 650D case is very good, it's top and front 200mm fans giving pretty decent cooling. I wouldn't hesitate with it. The x79 platform is a quad channel mobo for ram intense apps like video editind, rendering,etc. The Z77 is dual channel. The more channels the more info can be processed. Plus with x79 you could get the 6 core vs 4 core cpu, again for apps thst can use it. But it is more money. Depends on budget and level of rendering,etc. Hope this helps and keep us updated.
Asangard
Quote Reply Posted: 05 May 2012 at 3:15pm |
1. An SSD will booth up much faster. I would recommend having at least a 120GB SSD for your OS Drive. I would still recommend getting a HDD for a data drive. Most people here recommend the Intel 520 series SSDs.
2. No. You would see very little diffence (if any) between 2000mhz RAM and 1600mhz RAM. 3. Are you using your monitor for sound or do you have separate speakers? 4. The Corsair 650D is a mid tower version of the Corsiar 800D. These cases are very good if you are going strickly liquid cooling. They are not as good at air cooling as the HAF X. The HAF X is considered one of the best cases for air cooling. 5. X79 is the chip set used in motherboard that use the 2011 CPU socket. These CPUs are called Sandy Bridge - E (for extended). The 3820, 3930 and 3960 are the CPUs that use the 2011 socket. These chips are the highest end CPUs for desktop PC currently available. For gaming you would see no diffence between these CPUs and the Ivy Bridge 3770K you selected. bprat22 answered before I could. I would agree with bp that the 650D will handle air cooling but just not as well as the HAF X. I currently have the 800D but have a full LC system, and it does look really good.
Edited by Asangard - 05 May 2012 at 3:19pm |
Stealth1984
Quote Reply Posted: 05 May 2012 at 3:55pm |
Thank you both for the responses. I feel a lot more confident it being able to make my selections.
When adding a SSD to my order, do I specify that this the HD I want the OS loading from, or is it assumed that is where it will be installed and is unnecessary? As my order date nears, I will revisit this thread with any other questions or concerns I have. Again, thank you both for helping make a informed purchase. Cannot wait to order this bad boy :D Edited by Stealth1984 - 05 May 2012 at 3:57pm |
Quote Reply Posted: 05 May 2012 at 4:08pm |
Put SSD as drive one and DS will automatically put the OS onto it. Looking forward to your new config. Any questions, one of us can help.
Stealth1984
Quote Reply Posted: 05 May 2012 at 7:00pm |
Well, went a little over budget but I think this build has pretty much everything I want. Just made a few minor tweaks to bprats recommendations. In the end I decided to stick with the CM tower to ensure I have the best non-liquid cooling available.
Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master 942 HAF X Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core) (Requires Z77 Motherboard) Motherboard: ASUS SABERTOOTH Z77 (Intel Z77 Chipset) (Features Thermal Armor and Thermal Radar) System Memory: 16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 800W Corsair GS (Dual SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: Intel) (Model: 510 Series) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) Optical Drive 2: - No Thanks Internet Access: Wireless PCI 802.11n Up to 300Mbps (Supports 802.11n/g/b) Video Card: 1x NVIDIA GeForce GTX 680 2GB (Includes PhysX) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Phanteks PH-TC14PE Extreme Performance H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: - No Thanks Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro/Deluxe/Sabertooth Motherboard) Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: FREE: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Large) Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Final Price: $2,695.00 What do you think? Edited by Stealth1984 - 05 May 2012 at 7:02pm |
Alex
Quote Reply Posted: 05 May 2012 at 7:03pm |
Looks good to me! |
Stealth1984
Quote Reply Posted: 05 May 2012 at 7:33pm |
Anyone able to explain the difference in OS boost options?
1. FREE: Yes, Disable and tweak all of the non-crucial services on the operating system [+$0] 2. Yes, Disable and tweak all of the non-crucial services on the operating system [+$35] One seems to be free, while the other is $35. I want to have DS remove all bloatware before shipping out the system. Anyone know whats up? Edited by Stealth1984 - 05 May 2012 at 7:34pm |
Quote Reply Posted: 06 May 2012 at 4:14am |
Build looks great. Forget the boost options. It comes bloat free and you're better off picking what you do and don't want anyways.
If you go Deluxe mobo you don't need the wireless card, but that's a small thing unless you plan on sli in the future. Good Luck
Edited by bprat22 - 06 May 2012 at 4:16am |
Stealth1984
Quote Reply Posted: 06 May 2012 at 5:54am |
Thanks again bprat22, love the community on DS, great people here.
I don't plan to SLI on this rig. So, with this current motherboard do I still need the wireless card? Also, Do you have any certain recommendations for another/ better board I should purchase based on my needs? Edited by Stealth1984 - 06 May 2012 at 6:37am |
Quote Reply Posted: 06 May 2012 at 9:15am |
Yep, you need the wifi card with sabertooth. I've never checked into wifi boards, preferring hardwire myself, so can't help ya there.
Asangard
Quote Reply Posted: 06 May 2012 at 10:54am |
I don't have any experience with wifi boards either. I am like bprat22, hardwire all the way.
Hopefully someone else can chime in and help with this one.
Stealth1984
Quote Reply Posted: 07 May 2012 at 2:14am |
Well you both have been more than gracious with your time and input. Thank you again.
I will stick with this motherboard and order the WiFi card as an add-on. Should be no problem :) If I may ask one more thing, 800w power supply should be enough for this machine yeah? |
Quote Reply Posted: 07 May 2012 at 5:10am |
Yep, the 800W will be good.
