Monitor MAY be broken, how would I fix it
Post Date: 2018-07-16
Cminer View Drop Down
  Quote Cminer Quote  Post ReplyReply bullet Topic: Monitor MAY be broken, how would I fix it
    Posted: 16 Jul 2018 at 8:41pm
My moniter has an issue where whenerver i play a game (used to only be overwatch that did this but has spread to other games) The screen reverses colors somewhat, turning orange to blue and vise versa, purple to red, but not black to white. The cable is connected fully and i reset it. It is the "Asus 24 inch MG248QR Series (144Hz Refresh Rate) (1ms Response Time) (1920x1080)" i got it off digital storm.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 1:39am
I would try another cable. A failing graphics card can also cause monitor artifacts but not necessarily what you described.
If you have another video card laying around try using that to see if anything changes.   Try using your monitor cable plugged into the motherboard’s integrated graphics with video card removed.
This is just to eliminate the graphics card as the issue.
If it is the monitor then try changing its refresh rate, etc in the menu.   If it is the monitor you’ll need to replace it.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 1:46am
Sorry you are having issues with your graphics.
How did you determine it was the monitor. Have you tried the monitor in another system and it does the same? My experience with monitors is extremely limited. I have only had one monitor go bad (in too many years to tell) and it went dark and that was it.
What system do you have running it? Maybe it's not the monitor that is causing the problem.
  Quote Cminer Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 1:50am
I have a vanquish 7 level 1, so I have no graphics card and just have intograted graphics
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 2:08am
I hope its not the cpu. Try changing cable and if possible borrow a monitor from a friend and see if it still happens. No way to fix a cpu if it goes bad.
@bprat22: have to get coffee earlier, it takes me too long to correct my typing.LOL
BTW, some mobos have no integrated graphics.
Keep us posted. You might have to contact DS to help troubleshoot.
Edited by hoserator - 17 Jul 2018 at 2:12am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 2:16am
With the Vega11 integrated graphics try going to AMD website and updating the graphics driver.
If you have one available, plug in a graphics card and try using that just to see if it’s the monitor or the igpu.
My guess is a bad monitor.   Is there a degaussing feature on the monitor?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 2:27am
hoserator...we make a good tag team every morning.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 3:54am
  LOL You are way better and in depth as to solutions  (would have never thought of degaussing the monitor although did a lot of that with tapes) Strong I'm like make sure its plugged in type of solution. LOL
Edited by hoserator - 17 Jul 2018 at 3:57am
  Quote Cminer Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 12:14pm
After a bit of searching, i don't believe their is a way to degause (i know that's spelt wrong) my monitor.
I would love to follow your suggestions of try another video card or another monitor or this one on another system, but i'm a 13 yo subsisting solely on an amount of allowance that would let me get something like a new monitor or video card once every 2 years.
I'm mostly stuck with things i can do virtually, But ill see if i have another cable lying around.
  Quote Snaike Quote  Post ReplyReply bullet Posted: 17 Jul 2018 at 12:35pm
Call DS and have their Tech support run down the issue. After all if you got everything through DS there is a warranty, no?
Good luck.
  Quote Cminer Quote  Post ReplyReply bullet Posted: 18 Jul 2018 at 10:54am
So, i figured out how to fix it...
I just updated my graphics driver.
Do you ever feel like you have negative brain cells?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 18 Jul 2018 at 11:46am
We recently had another with an issue where updating the Vega11 drivers fixed it, that’s why we recommended the update a few posts back.     Graphics drivers can simulate all kinds of hardware issues, from monitor, to graphics card, etc.
Congrats.
Jerrar View Drop Down
  Quote Jerrar Quote  Post ReplyReply bullet Posted: 24 Jul 2018 at 5:15am
Nice that your issue is resolved. What happened to my monitor once was that the connector port on the monitor where the HDMI plugs in was damaged at it gave out weird colors.
I got the port replaced and it still works fine.
... fixed broken quote ...
Edited by Snaike - 24 Jul 2018 at 8:29am
