My DS System Review
Post Date: 2011-03-04
damet View Drop Down
  Quote damet Quote  Post ReplyReply bullet Topic: My DS System Review
    Posted: 04 Mar 2011 at 7:48pm
I've had my DS computer for about 3 days now and decided to write an early review. I will update my thread with more pictures and bencmark results as I do them, and also any important thoughts I have on the system. I will also do another review of the system after 6 months.
Computer Specifications
Motherboard: ASUS P8P67 Deluxe (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s)
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance)
Video Card(s): 1x NVIDIA GeForce GTX 580 1.5GB (Includes PhysX) (EVGA Black Ops 015-P3-1583-AR)
CPU Boost: Stage 1: Overclock the processor between 4.0GHz to 4.7GHz (Cooling Upgrade Recommended)
Overclocked Processor Settings
Processor Speed GHz: 4.6
CPU Multiplier: 46
Voltage CPU VCore: 1.296
VDroop Control: Yes
i7 - BCLK MHz: 100
Monitor: Dell Ultrasharp U2311H
Pictures
First off, this box is huge. I'm a pretty big guy and I had a hard time carrying the box up to my apartment.
The case on the side with the filling still inside.
Took the fillings out to take a peak inside. As you can see everything was nicely arranged, clean and organized wiring. You can also see the VGA bracket and the air duct (is that what it is?) that the HAF X case comes with. You know that brand new smell of something? Well, it never smelled better!
A closer look at the Noctua U12P fans.
*UPDATE*
Here is the system from the front turned on.
Here is the system from the top. Nice lighting as you can see.
Picture of my current setup. I know..it isn't the best setup, but I have too much stuff on my desk. I need to clean up my desk and then I will put the computer in a better spot.
System Review
The performance of this system has met my expectations. Without a doubt, this is the best computer I have ever owned. The first thing I noticed when I turned on the computer was that the fans were kinda loud. However, I believe DS makes the fans speed at maximum for the maximum air flow, so I guess I was ok with that. Anyways, on to the next thing. Windows 7 booted up in about 10 seconds. I can't tell you how awesome that is since my last PC took 2 mins to boot up. The second I saw my desktop I was able to open Firefox instantly and starting surfing. That's just incredible. SSD all the way guys. Everything just loads instantly.
The first game I installed was Starcraft II. Of course, it ran perfectly on Ultra settings. Since then I have installed many other games, such as Crysis, Metro 2033, and L4D2. Everything ran smoothly and the computer didn't even seem to finch. Hell I could run Starcraft II and Crysis at the same time.
As you can see the processor is clocked to 4.6ghz. During the idle time because of intel speed step the computer will clock itself down to 1.6ghz. The second it realizes it needs more speed it will clock up to 4.6ghz. Pretty good feature if you ask me. Another good thing is that the voltage drops when the system is idle, saving power and cpu life. At full load the voltage jumps up to as high as 1.346. Sandy Bridge is definitely a beast of a processor. My last comp had a C2D E8500, so this was a huge step up for me.
The only thing that I wish was better were my CPU temps. After a few hours of Prime 95 and LinX tests, my max CPU temps ran around 78C. That's pretty high, but I can live with it. Might be because of my high ambient temperatures (my room doesn't have A/C), as I live in Hawaii. I probably would have ordered the Noctua D14 fans instead of the U12P fans if I could go back.
*UPDATE*
3D Mark 11 Performance Run (GTX 580 overclocked to 900/1800/2200)
3D Mark 11 Xtreme Run (GTX 580 overclocked to 900/1800/2200)
3D Mark Vantage Performance Run (GTX 580 overclocked to 900/1800/2200)
Customer Service
I think this is the area where DS really shines. Their customer service is unmatched. Everytime I called in, I got a real polite representative that cared about my concerns and questions. The technicians actually knew what they were talking about and went out of their way to explain certain things to me. Alex was very helpful and fast. Everytime I emailed him, he would get back to me within 10 hours. Alex kept me updated on my order and never failed to address me on an issue. Finally, I really like their stage process and how up-to-date they keep it. The second my computer reaches a new stage I get an email. The stages are well explained and keeps the customer well informed. Excellent customer support system if you ask me.
There is one thing that DS did fail to do. I noted in my computer order to add the 200mm fans on top, and even called in to make sure they had that noted. Sarah confirmed they reached the note and will install the extra fan. She also mentioned it will be an extra charge of about $20. I said ok. Well I didn't get the extra fan in the case, but it's no big deal since I wasn't charged for it either. So yah, meh, no biggie.
Conclusion
I've done a lot of things in my life that I really regret, but I am happy to say that buying a DS computer is not one of them!
Edited by damet - 04 Mar 2011 at 11:09pm
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 04 Mar 2011 at 8:20pm
haha nice review, i'm guessing you didn't go with the intel b3 sata 6gbps fix why not?
but really nice review, if you ask alex i'm sure he'll be sure to send over the 200mm fans they forgot.
and show some pics of the rig on ur desk plz.
Steam:pcmaster160
  Quote Alex Quote  Post ReplyReply bullet Posted: 04 Mar 2011 at 8:45pm
@damet,
I'm glad to see that you're happy with your system!
Please send me an email: [email protected] with your order number and reference the fans. I'll check your order, and if you did tell us about this and they were not in there, I'll try to get you a free set shipped and we'll cover the shipping on them too.
  Quote damet Quote  Post ReplyReply bullet Posted: 04 Mar 2011 at 9:44pm
@maxyme
I didn't go with the B3 version because the only thing connected to my SATA2 is my CD drive. My SSD and HDD are connected to SATA3. I barely ever use CD drive as I download most programs and don't do much burning. So the problem will most likely never affect me.
Edited by damet - 04 Mar 2011 at 9:44pm
  Quote damet Quote  Post ReplyReply bullet Posted: 04 Mar 2011 at 10:32pm
Updated some pics of my rig and some benchmarks.
Edited by damet - 04 Mar 2011 at 10:41pm
  Quote maxyme Quote  Post ReplyReply bullet Posted: 04 Mar 2011 at 11:54pm
hey you have the same speakers i have for my parents computer they cost $5 on amazon i think lol
and eventually you will have to get a addon card for the cd drive because it will stop working at all eventually.
Steam:pcmaster160
  Quote RiceEatin2000GT Quote  Post ReplyReply bullet Posted: 05 Mar 2011 at 4:06pm
congrats!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Mar 2011 at 4:15pm
Oh man that pc with the Dell Ultrasharp U2311H monitor
Congrats
Your temp of 78c is very good actually for a warm room and full stress, but IMHO its more important you see what your max temps are with your use, linx and etc puts the pc under load that normally it would not do, so check and see after a full day use, what your max temp was.
4.6 oc with air cooler and 78c load temp in a warm room is pretty good IMO.
Edited by DST4ME - 05 Mar 2011 at 4:19pm
Karn View Drop Down
  Quote Karn Quote  Post ReplyReply bullet Posted: 05 Mar 2011 at 9:34pm
Congrats!
45BDE View Drop Down
  Quote 45BDE Quote  Post ReplyReply bullet Posted: 05 Mar 2011 at 11:34pm
Congrats!Awesome
  Quote damet Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 2:21pm
Correct me if I'm wrong, but I'm pretty sure DS connected my CD drive to the Marvel Ports. Therefore, I don't think I'm at any risk as nothing is connected to my SATA2 ports. Even if my CD drive was connected to my SATA2 port, the chance of degradation is 5-15% and that's over constant use, which I only use the CD drive like once a month lol.
  Quote Alex Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 2:36pm
@damet,
That is correct.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 2:51pm
Oh I thought threre were only 2 sata 3gbps ports
Steam:pcmaster160
Regent Square View Drop Down
  Quote Regent Square Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 6:10pm
I am glad for for you man! BTW how your pc works, is it quiet or loud?
Thank you
  Quote damet Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 6:51pm
It's alright. The fans are a little loud, but you get use to it and it doesn't bother me anymore.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 6:56pm
i think everyone over reacts to the fan loudness in cases. Like i've had a cooler for my laptop because it has no internal cooling and it overheats if i don't have it on. And its noticeable and bugs you for the first week but after that you get used to it or play music or something to drown it out. But it does vary per person but to me its not really a big issue because you can just adapt to it.
Steam:pcmaster160
  Quote Regent Square Quote  Post ReplyReply bullet Posted: 16 Mar 2011 at 8:55pm
Yep, what should i except from a beast powerful machine. Noise of power!
  Quote damet Quote  Post ReplyReply bullet Posted: 18 Apr 2011 at 3:05pm
So, I cleaned my desk up and reorganized my setup. Also got my U3011. Here is my current setup if anyone cares Big%20Smile
  Quote maxyme Quote  Post ReplyReply bullet Posted: 18 Apr 2011 at 4:23pm
Nice looks like my desk except I have another desk behind me for my laptop and schoolwork
Steam:pcmaster160
